Transmission heater?
Is there a heater of some sort in the tranny on these trucks? I ask because my tranny temp gage comes up within less than one minute after startup first thing in the morning no matter how cold. It'll reach nearly it's normal position before the engine temp gage even budges. I can't believe that it could warm up so fast without help. It seems to act as though it's reading exhaust temp.
I doubt it. My tranny is almost to the middle mark when the Scangauge has the actual temp still under 100 degrees. Got two neighbors trucks that have similar readings. The factory gauge works more like a stepper swich with not enough levels in it. Junk!
The OP said his gauge reads in the middle in less then 1 minute, I'll bet his actual trans temperature starting in the morning will increase less then 5 degrees in 1 minute.
Received 5,160 Likes
on
+1 for scangauge
they just added a bunch more x-gauges thats not listed on the scangauge website plus ficm,and a bunch of others
and I wonder with the transmission temp . At idle in park only half the torque converter is spining creating alot of energy that is going nowhere therefor heating the fluid up fairly quick
At idle in park all of the torque converter is spinning. There is very, very little energy being used in the converter. In gear only half is spinning. Now there is significant energy being used, which will heat the fluid. In park there is almost no heat being added to the ATF.
The stock gauge is calibrated to be in the middle of the range when the trans temp is between 50 and 230°F.
