Stancor relay 586-902 vs OEM GPR warning........Maybe??
Old 03-29-2011, 09:13 AM
makomark's Avatar
makomark
makomark is offline
I measured the 'initial' current draw at 160 amp two weeks ago. This was with the air temp @ ~ 40F. This was with a FLUKE Clamp Meter and it took a couple seconds from key on to check the meter.
Splitting the GP load across two relays would definitely extend their lifes as the current thru each would be halved...other than the mounting issues, seems straight forward.
Another idea would be to add a suppressor circuit across the contacts, something as simple as an R-C filter....just food for thought.
  #62
Old 03-29-2011, 09:55 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Bill, that's for the 70-902=copper contacts.
586-902=silver
  #63
Old 03-29-2011, 11:23 AM
MADVAN's Avatar
MADVAN
MADVAN is offline
586-902=silver
My bad. I looked at 70 series not the 586 series.
B
  #64
Old 12-07-2013, 01:36 PM
stever88's Avatar
stever88
stever88 is offline
Hi All!
Just found this very good thread and had a question - would a Stancor 586-903 Relay rated at 16 VDC help extend the life of the Relay?
Thanks - Steve
  #65
Old 12-07-2013, 03:54 PM
Hussler's Avatar
Hussler
Hussler is offline
Originally Posted by stever88
Hi All!
Thanks - Steve
No, it would have trouble energizing if at all. It's not the coil DC rating but the contacts current rating that is important.
  #66
Old 12-07-2013, 05:16 PM
stever88's Avatar
stever88
stever88 is offline
Thanks Hussler, appreciate the Reply - Happy Holidays!
  #67
Old 12-07-2013, 07:15 PM
JCart's Avatar
JCart
JCart is offline
Hi All!
Thanks - Steve
Is the 16VDC the max volts the relay can handle so presumably it will be more robust than the 902 which is rated at 14 iirc?
  #68
Old 12-08-2013, 10:26 AM
stever88's Avatar
stever88
stever88 is offline
I think Hussler's Reply answers your question … but I am not very proficient with electrics.
ZeroTucker
10-11-2016 11:30 PM
Stolher
Ford Truck Parts for Sale
03-12-2016 10:56 AM
bkuuz1
09-20-2015 07:36 AM
guzzle92
99
02-26-2010 07:15 PM
kawa
10-26-2009 08:06 PM
Quick Reply: Stancor relay 586-902 vs OEM GPR warning........Maybe??
