turbo question
please use proper grammar-
that part is the CCV, it has two 10mm bolts that you can get to by removing the engine cover.
if your orange intake boot is falling apart,you can get a new one from RiffRaff-
https://www.ford-trucks.com/forums/1...nk-inside.html
Other than a Boost Gauge, is there a way to tell if the Turbo is "effective" (used loosly). I can tell that it kicks in, but I don't feel like it is working as well as it should. i.e. I was towing a 11K Toy Hauler up a minimal Grade and the Turbo kicked in (as usual) and I had to mash the pedal to keep it over 50MPH and to keep the tirbo spooled up. First few trips towing so I am unsure if this is normal or not.
Thanks all,
Thanks all,
I'm sorry, my bad I was typing those previous posts off my cell. Also this diesel is my first vehicle and still learning. When I was in there though the hose clamp that holds the intake to the turbo was loose so I tightened it up, but I'm away from my truck right now so I will have to get back to you.
mustangsvo85
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
25
03-03-2016 07:08 PM
CrazyCajun
10-05-2015 11:34 AM
hittman1422
236
08-01-2009 02:14 AM
