Leak under brake pedal
I think I have the answer to this. I had the very same problem, went to the dealer and they showed me were it was coming from. It's the adjustable pedals. Theirs a small black box attached to the adjustable slide and where the tubing goes into it is where the leaks was. It was caused from heat from the heater which makes the viscosity change. They think it was overloaded with this clear oil and once winter passes and the slide is used several times it will go away. This is what Ford told them. Anyhow, the problem no longer exist.
fordbozo
05-14-2017 07:06 PM
grinnergetter
09-27-2015 09:20 PM
cr506
18
04-08-2010 08:16 PM
