2011 Tire Replace -will 285/75/18 rub?
A friend just picked up his 350 CC 6.7 & it has Continentals.. He ranches full time and has usually run Toyos - I think the Open Country A/T. He asked about running bigger A/T's - He has 8"x18" wheels onto which a 285/75/18 will fit as per the Toyo site.
My question - Has anyone run this size on Stock truck (No Lift). The Overall Diameter is 34.8".... will it rub without a lift?
Thanks for any comments..
Pictures if you can, thanks.
Did he end up getting these? I have 18" wheels also and would like to see some pictures with a bigger tire. Cannot decide if I want to stick with the 18 or go to 20 when I replace my tires. (and yes I have seen plenty with the 20's so I know they look good )
Will get picts when possible!
Quite a bit of info related to F-350 trucks but not much luck with the F-250 trucks.
I'm sure there is a height difference between the two that would make the 285/75/R18 Toyo possibly too large for an F-250?
Again, no experience and I'm guessing.
Byram, are your BFG tires 285/65/R18 since that's the only BFG 285 option (at least that I can find) for the 18" wheels?
...unless of course you have the 17" wheels.
Still reading and attempting to decide what I'll replace these Conti's with but sooner or later, they have to go.
Seems like the BFG 285/65/R18 is a safe option to go with.
I too would like to see some pics with bigger/wider tires on the stock 18" rims. I really don't want to go to aftermarket wheels and lose the ability to completely unlock the front axle.
