E40d Problem
Old Mar 16, 2003 | 08:21 PM
BADASSF-250's Avatar
BADASSF-250
Angry E40d Problem
i have a 95' f-250 psd w/ e40d transmission. just recently the overdrive lite started blinking, and when it does the transmission seems to shift harder as if the fluid pressure is raised. anybody know what this means, other than take it to a shop? please let me know.
thanks
Old Mar 17, 2003 | 07:56 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
E40d Problem
It means the computer has detected a transmission problem. You need to get the codes read to find out what is wrong.
Old Mar 17, 2003 | 08:11 AM
steve83's Avatar
steve83
E40d Problem
If it's not a MAF engine (OBD-II), you can pull the codes yourself.
Old Mar 18, 2003 | 07:54 AM
Lkfranz's Avatar
Lkfranz
E40d Problem
Ahhh, the classic hard shift. This is your converter, I have a 97' F350 and it did the same thing. Took it in and the converter was shot causing the hard shifting. If it is controlled by a computer, try disconnecting your battery terminal for 15 minutes and then see what happens. This should reset your computer causing it to shift normal for a awhile. You will eventually have to replace the converter. I just put 30,000 on my rebuilt transmission and I have to rebuild it again! Freakin' E4OD are crap. I have been told which I am goin to do thid time around to add an aftermarket transmission cooler and take it off of the radiator ( not too sure if yours is like this) and it should add around 30-40,000 miles on the rebuilt trnasmission. Hope this helps.
