Testing An Ignition Coil
Hey everyone I'm working on my 79 and lost all power driving home today. I replaced the dis cap and router thinking that was it but still wouldn't spark. So I'm thinking my ignition coil needs to be replaced but I was wondering if there a way to test it before I buy a new one. I have a volt meter but what do I need to have it set on or is thier another way?
You can do a quick check to look for open or shorted windings by using your multimeter to test resistance. You can check the primary winding by measuring between the BATT terminal and the TACH TEST terminal; you should see about 1.0 ohm. In reality you will see a few decimal points higher than that (closer to 1.5 ohm) because the lead resistance of many commercial multimeters is significant in this case. You can check the secondary resistance by measuring between the BATT terminal and center terminal; you should see 8 to 11 Kohms. If your meter does not auto-range, you will need to adjust it accordingly.
However, coils actually rarely fail. What fails is the mechanism behind what makes the coil fire. With the coil connected, connect a test light from the TACH TEST terminal of the coil to clean, unpainted metal on the engine. Crank the engine over with the key, and the light should BLINK. Report your results.
If you don't know what has failed, you don't know what to replace. Simple as that. A few diagnostic steps will reveal that information.
Over 60 degrees (or whatever it was) and after an hour or so of driving, whether non-stop or errands, the engine would start acting up.
Turned out the weird "oil leak" I couldn't trace was actually the coil leaking it's internal oil when it would get hot. Which also would cause an erratic mis-fire.
Stupid coil. Stumped me for the longest time.
Josh
Genadekw
05-12-2016 02:57 PM
V8SHO
1997-2006 Expedition & Navigator
30
03-16-2016 10:10 PM
Broncojunkie
19
12-19-2014 07:53 PM
73CaliF100
04-29-2009 04:12 PM
