Ring and Pinion gears
OK, I know I'm going to sound like an idiot, and perhaps I am. I thought I had checked my U-joint, you know, grabbing the drive shaft and yanking it in all directions to see if there's any play, and I didn't feel or see any. This is the U-joint at the differential. Well, it blew up on me today. I checked the play in the pinion by rotating it back and forth, and maybe there's a one degree play in it. I don't have a caliper as yet so I didn't check the play when the cover was off. This is actually the third U-joint in five years that's worn out. The truck does have three inch lift blocks between the springs and axle in the back and one inch blocks in front. The angle of the drive line doesn't look too excessive, but I'm no expert. Could a worn ring and pinion gear cause the U-joint to wear out? Or to much of an angle between the drive line and flange?
I use 80W-90 gear oil and 1 tube of LS additive.
The one inch blocks on the front axle assemble are longer than the square axle housing, meaning the blocks protrude slightly both in front and behind the axle housing. They are in there solid.
I have a new u-joint in and the truck drives like before, no noise. My grabbing a hold of the drive line and shaking it wasn't a good test method, because it didn't show the u-joint being loose or starting to wear out. Only when the vibration got worse and it blew up did I find out the u-joint was bad. I was so focused on the ring and pinion. I should have taken the u-joint loose from the pinion flange and checked it that way.
I looked at a friend's stock F250, standard cab. So he has a single drive line. Mine's extended, to I have a two piece. The stock truck has a 2 inch block between the rear axle and springs. I'm assuming mine would be the same if it hadn't been modified. Mine have been replaced with the 3 to 3 1/2 inch wedge shaped blocks, so one inch lift. This time I stood back and looked, instead of being under the truck and too close. Of course a properly angled drive line to pinion setup would have a negative angle, the drive line coming down from the tranny and angled up to the pinion via the u-joint, the pumpkin more or less level. Mine is doing the opposite, a positive angle. The drive line comes down, but the angle to the pinion comes down even further. The front of the pumpkin is angle up way too high. I think this is what's causing me to eat up the pinion u-joint.
I think whoever installed the lift put the blocks in backwards. My next step is to turn the blocks around, which should angle the pumpkin back down in the front and see if that corrects my drive line to pinion angle.
Any other thoughts welcome. And if I'm wrong somewhere here, please let me know. Thanks
Received 3,566 Likes
on
Update, for those still interested.
I finally loosened the u-bolts and turned the lifting blocks around. Set the springs back down on the axle and boy, what a difference. The drive line to pinion angle is now negative, like it's suppose to be, and the angle is 2 to 3 degrees. It looks like a stock set up now. I think I'm even feeling it drive better
So hopefully I won't be blowing up u-joints. Time will tell.
Thanks to all for the help.
on
I'm glad you got it figured out. Not sure if anyone said this yet but the driveline angle split matters a whole lot more than the pinion angle alone. When I went to Ford and GM vibration analysis school they said to always shoot for 1/2 degree, no more no less difference between the front and rear. If they are zero they will make noise. Too much and it will make noise. I hate messing with U joints but rear ends are easy. You can shim the carrier bearing if you need to to get the split in tolerance. Also shim the rear axle if needed. You have to measure it by measuring the angle of the driveline on each side of the u joint. Then get the difference. Do that front and rear and look at the difference between front and rear. That is the angle split. go for half degree and they will stay in phase and be quiet.
Just more worthless info I like to throw out there.
1fixitman
12-19-2012 02:06 PM
