Don't know what else to do
I have been trying to chase down a whirling noise that follows vehicle speed since I bought the truck in my sig in Oct. The noise happens whether or not the hubs are free or locked so I don't think it is the front needle bearings. I just changed the transfer case fluid over to Mobile 1 Syn. and there was no change in the noise. I also changed the front pads, rotors, slide pins and calipers a few weeks ago and that didn't have an effect on the noise either. Today I took the truck for a ride and I'm not sure but it seems almost like the noise is a bit louder! And I noticed that if I hit the brakes firmly, harder than a normal stop the noise gets significantly quieter and if I release them again the noise goes right back to normal. This has got me stumped...
Along with this noise, I have a vibration on the freeway that gets worse around 55 and lets off around 61. Its worse at some speeds and better at others. Thinking the two were related I pulled the rear drive shaft and checked the u-joints and the carrier bearing for play. The carrier bearing doesn't have any real play but there is quite a bit of slop, ability to turn back and forth, where the driveshaft comes out of the transfer case. All but one of the u-joint cups were fine. The bad one isn't even too bad just the rubber seal around it is a little off, there is still grease in it and the needle bearings seem fine.
I am at a real loss so sorry if this is long and circuitous. I really need some help!
on
I have rotated the tires, which are in really great shape actually, no difference. This is a noise that only seems to be affected by vehicle speed. I have not replaced the power steering fluid, but it is at the proper level and I know thats not the problem bc I have pretty loud ps steering whine in addition to this other noise the OP is about.
You can have a bad wheel bearing without them being sloppy.
Try driving on a deserted stretch of road and swerving back and forth hard enough to unload the inner race of the front wheel bearing, similar in fashion as if you were driving a slalom course.
If the noise goes away momentarily, then it's a bad bearing on the side that you are turning away from.
I don't see how this would be a powersteering or brake booster issue...
The belt tensioner is brand new I just replaced it, the belt, and the idler pulley, also can't see how this is applicable....
Kwik, I'll be hard pressed to find a road around here to do this but it's nice outside so I guess i'll go for a long drive today, thanks for the help. I'm not sure the noise is coming from the front though...sounds like it is from behind the front seat....?
I wish I had an ABS hole to grease through, darn 99.5 xlt's...I have been slowly putting parts on the truck since I got it and the wife is getting a bit fed up on our budget so I may just be living with it for a little while if I do have to do the bearings...
