8.8 replace or gear swap
Old 01-09-2014, 12:00 PM
quincyj34's Avatar
quincyj34
quincyj34 is offline
Currently I have a 3.08 open and I want to go with a 4.10 lsd and Im looking for my best option. I have a shop near me that will install everything for me fr about $300 and I saw rebuild kits on bronco graveyard, one with duragrip lsd for $700, and one with trac-lok for $575. Or would I be better trying to find a limited slip diff with a 4.10 in it at the junkyard and have it rebuilt?
Old 01-09-2014, 01:54 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
A junkyard unit will be cheaper, but it will be a friction disk type diff. In fact, it is the same as the trac-lok. Personally if I was going to spend the money, I would go with the Detroit True-Trac. It is an LSD with no clutch disks so it will basically not wear out. That kit is $725 from JBG.
Old 01-09-2014, 02:02 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
I got a complete rear with stock lsd and 3.55s for $75. When I find a deal on some 4.10s or 4.56s, I'll grab those up and throw them in. I'm in for next to nothing at this point though other thana couple hours of work. I painted it and made it look good too. Everybody recognizes my silver diff cover.
Old 01-09-2014, 02:58 PM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
You won't find a 4.10 truck 8.8 very easily in a junkyard. That ratio was only offered in Lightnings.
Old 01-09-2014, 04:07 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
Didn't some explorers get them?
Old 01-09-2014, 05:12 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
I would not hold my breath or go out of my way to find a complete axle, one from an Explorer will not fit, with a 4.10 ratio. Get a Trac-Loc carrier with whatever ratio you can find then change out the gears to 4.10. Rebuild the Trac-loc with carbon fiber friction plates ( http://www.summitracing.com/parts/fms-m-4700-c ).
Old 01-09-2014, 05:47 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
I was going to pull the gears from an Explorer.i don't care to install them.
Old 01-09-2014, 08:18 PM
mefast's Avatar
mefast
mefast is offline
Newer Mustangs use an 8.8 rear axle too. Lots of people upgrade to them, so there might be some in junkyard cars nearby or maybe someone on CL is looking to sell off an axle with them. Worth a look at least.
Old 01-10-2014, 05:28 AM
Bob Gervais
Trucks are a different spline count axle than Explorers and cars. Removing the gears off the diff and swapping onto a truck diff will work, but I'm not really sure it's worth all that effort. New gears aren't that expensive.
Old 01-10-2014, 08:44 AM
mefast's Avatar
mefast
mefast is offline
2011+ mustangs use 31 spline axles. Don't our trucks use the same?
Old 01-10-2014, 08:56 AM
Jarryd's Avatar
Jarryd
Jarryd is offline
Yes, but those won't have the ring on them that sends the signal to the speedo.
Old 01-10-2014, 10:33 AM
Evan_P's Avatar
Evan_P
Evan_P is offline
Gear sets are cheap enough to buy that unless your buying an entire 4.10 axle from an F150, it is better to buy new gears. I found Ford Racing ring and pinions on ebay not too long ago for ~$130 shipped brand new.
Old 01-10-2014, 12:18 PM
quincyj34's Avatar
quincyj34
Ok so how hard is it to rebuild the trac lok. I can get a complete rear end for $100 out the junkyard and throw in the gears I want. I would love have the detroit true trac. I just dont know what would be the best option its either forking out the $1000 to have it done professionally or getting lucky and finding an axle that isnt complete destroyed and put it under my truck
Old 01-10-2014, 12:32 PM
rla2005's Avatar
rla2005
rla2005 is offline
About half-way through this write-up are instructions for rebuilding your Trac-Loc: 8.8 Axle Gear Install
Some good info here too:
Old 01-10-2014, 12:55 PM
quincyj34's Avatar
quincyj34
I was just watching that. It doesn't seem hard at all. What is the hardest thing to do when rebuilding an 8.8?
Quick Reply: 8.8 replace or gear swap
