Headlight adjustment on F-150
Old 03-15-2011, 12:57 PM
Vaccuum's Avatar
Vaccuum
Vaccuum is offline
I replaced the lamps and now I am remounting them.
What is the procedure for adjusting the headlight on a 2002 F-150, V8, 5.4, 2WD?
I need to align the light beams.
Thanks,
Mike
Old 03-23-2011, 12:40 PM
Vaccuum's Avatar
Vaccuum
Vaccuum is offline
Nobody? Nobody knows how high they should when facing a wall? Before I put the grill back on, I want to know the set up.
Somebody, somewhere must know, they just aren't telling me.
Hmm.
Thanks,
Vaccuum's Avatar
Vaccuum
Vaccuum is offline
Hmm.
Thanks,
Old 03-23-2011, 09:43 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
i park on the flat facing the garage door. adjust then so they are basically horizontal meaning if the llights are 32 inches off the ground, get the light pattern on the door 32 inches up from the ground. On the width, the main light beam should for left and right will be about 5 ft apart on the door in front of you. Of course the beam spreads out and will shine into the left lane and off the side of the road, but that looksmore like a reflection on the door.. The real conclusion is to drive it down the road at night and see what i think. I normally do this and see register in my own mind that the drivers side needs to move (up- dowon- left-right) , etc, then the passenger side needs ???. Go back to the driveway, make minor adjustments and do it again on the road. I have never got it right the first time without a road test and movement.
InsanePyro
05-22-2017 09:37 AM
Hotairjunkie
1999 to 2016 Super Duty
05-21-2017 02:29 PM
MrBonez
Modular V8 (4.6L, 5.4L)
04-03-2017 07:29 PM
Bat4x4
2017+ Super Duty
03-27-2017 09:06 AM
Ezalycasaid
2004 - 2008 F150
02-27-2016 03:08 PM
Quick Reply: Headlight adjustment on F-150
