Drag Trucks
Old 03-10-2011, 02:06 AM
NUTTY4X4's Avatar
NUTTY4X4
NUTTY4X4 is offline
Drag Trucks
Well im in the process of building a drag truck and after searching and seeing a few in the lowered truck section i wanted to get them in one thread. So lets see em AND specs, motor/mods et's etc. Thanks
I got the drag bug after buying a F100 and runnin a 7.80 in the 1/8 with a bagged out 351m ......and now the 460 and 4:10 gears are goin in, im sure a little shot of nitrous will make the stock heads flow till i can afford hi-po goodies
Old 03-10-2011, 08:05 AM
whistle1516's Avatar
whistle1516
whistle1516 is offline
Nutty, around Kansas city we run the 1/4 mile. I'm always confused of 1/8 mile times. What does 7.8 roughly break down to in a quarter mile?
Old 03-10-2011, 09:31 AM
MikePacey's Avatar
MikePacey
MikePacey is offline
If my memory serves correct when my dad ran his 11 second chevelle 7.80s should be high 11 low 12s
79 shortbed lover's Avatar
79 shortbed lover
79 shortbed lover is offline
I believe it would be running mid 14's
Old 03-10-2011, 09:51 AM
NUTTY4X4's Avatar
NUTTY4X4
NUTTY4X4 is offline
yeah mid 14's-15's in the 1/4 is about right. Its all we got here unless i go to mission for the 1/4. The feeling of being "allowed" to hammer full throttle and race is awesome
Old 03-10-2011, 10:15 AM
maverickman514's Avatar
maverickman514
maverickman514 is offline
IIRR 1/8th mile times are ROUGHLY 60% of your 1/4mile times... provided the car/truck is built for the 1/4mile tracks.... Some people who ONLY race 1/8 mile tracks will build the cars for max performance on the 1/8th but usually involves too much rear gear to make a full pass at a 1/4 track....
a 7.8sec 1/8 pass should net about a 13.5 1/4 pass.... NOT ACCOUNTING FOR MECHANICAL SHORT COMINGS ... valve float, over geared, under geared, slipping trans/clutch... etc etc
Old 03-10-2011, 10:21 AM
NUTTY4X4's Avatar
NUTTY4X4
NUTTY4X4 is offline
^^^ you are totally right, thanks for clearing that up. Now lets see pics/vids and specs of drag trucks!!!
Old 03-10-2011, 10:36 AM
NUTTY4X4's Avatar
NUTTY4X4
NUTTY4X4 is offline
well not the best way to start the thread but the 460 goes in today(had to put the stock tires on the front to clear the engine hoist)
Old 03-11-2011, 09:05 PM
purgeofdarkness's Avatar
purgeofdarkness
purgeofdarkness is offline
This will hopefully be the greatest thread of all time. I'm looking foward to seeing what everyones gonna do.
Old 03-11-2011, 09:12 PM
MikePacey's Avatar
MikePacey
Are you missing part of your frame in that pic?
Old 03-11-2011, 09:24 PM
Sleepy445FE's Avatar
Sleepy445FE
Sleepy445FE is offline
He'll probably never get over here from the FE forum so I'll post it up. This is Scouder's 511ci FE powered highboy.
YouTube - F250 6.97 at 99.7 mph in 1/8 mile. Track Record!
Check out his channel for other vids. The thing was so bada$$!
Old 03-11-2011, 09:37 PM
NUTTY4X4's Avatar
NUTTY4X4
NUTTY4X4 is offline
No, anyways just need header gaskets and i can flash mine. That 4x4 drag truck is sweet!
Old 03-12-2011, 07:13 PM
martin0605's Avatar
martin0605
martin0605 is offline
I am starting with a 75. Lets see if I can load a pic on my first post. I have had this truck as a daily for about 8 yrs now. Its now sitting at a buddy's house waiting for me to get started.
Nope can't post as of yet,but as soon as I can I'll get the pic up.
Anyway,it will have a built 351m w/edelbrock heads and intake and camshaft to match. Lowered i-beams and possibly a 4 link in the rear. Not sure yet. I've seen a truck on here running leafs with slapper bars. The block will be beefed up with aftermarket splayed main caps for strength.
A C-6 with a brake and full manual valve body. I would go with aBBf,but this motor was free!!All of my project ideas are on hold as of now. The earthquake and tsunami in Japan is takin its toll on my job,as I work a supplier to the local Toyota plant. We are down to a 3 day work week for an undetermined time.
Old 03-12-2011, 07:33 PM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
When you need to start making a cage give me a call.
Old 03-12-2011, 08:18 PM
TheTowingCowboy's Avatar
TheTowingCowboy
TheTowingCowboy is offline
A drag truck is what I am somewhat shooting for with my 78 F100, mines going to be a street strip truck getting a 460 in front of a 4spd.
Quick Reply: Drag Trucks
