Hey all , I am in the process of changing gears from 3.73 to 4.30 and I came across an add on craigslist with a guy that sells new ford axles. He has one with 4.30 and LS complete with rotors my question is what do I need to look for so that the speedo and the abs works. Its a f350 axle and its going into a 2003 f250. Thanks for the help
Ok Cartmanea I talked to the guy with the axles , his company bought about 1200 early production ford axles from 1999 and 2000 He sells these axles to ford dealers around the country. He said the only thing different is I will have to flip my drivers side rear brake caliper so that its in front of the axle instead of behind. I guess on the 2000 f250 one caliper was in front of the axle and one was behind. Other than that they are complete and everything will plug right in. What do ya think?
i know that 99 SD's had the one caliper swapped, in 2000 ford switched it to both in the rear of the axle. If it's a 2000 axle they should be in the rear if not i wouldnt buy it. Ford switched this for a reason you know.
I love mine, but I did plan on 37s when I installed them. With a 5.4L though, 4.30s and 285s should be a great combo. On my 6.0L the rpm's get up there on the highway, but not too bad.
