1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Need help with rear end vibration
Old 03-06-2011, 03:12 PM
SloSupra's Avatar
SloSupra
SloSupra is offline
Hello I own a 2002 Expedition 2wd. The truck drives great the only problem I have is on the highway about 50mph the rear end vibrates for just a second and it feels and sounds like we hit the rumble strip real quick but we dont. It does not happen any other spped just around 50 and like I said only last for a second. Any ideas???????
thanks
Old 03-06-2011, 03:20 PM
alloro's Avatar
alloro
alloro is offline
Received 4,201 Likes on 2,436 Posts
I'd start with an inspection of the driveshaft u-joints to see if they're worn.
Old 03-06-2011, 08:21 PM
pdqford's Avatar
pdqford
pdqford is offline
That would be about the speed that the torque converter clutch locks up in overdrive. I suspect that you are experiencing torque converter clutch chatter. When was the transmission fluid changed last? Usually changing the fluid eliminates the chatter.
Old 03-06-2011, 08:27 PM
SloSupra's Avatar
SloSupra
SloSupra is offline
That's a great question I just bought the truck so I am not sure but I will look into changing it tomorrow and hope it fixes it.
thanks
Old 05-02-2015, 01:56 AM
upurz1's Avatar
upurz1
upurz1 is offline
thanks
I'm experiencing the same problem on my 2002 lincoln navigator. Did you find a solution?
Old 05-02-2015, 06:43 AM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
He hasn't been here in 4 years, but luckily for you alloro and pdqford are still here to help.....
Old 05-02-2015, 09:29 AM
r2millers's Avatar
r2millers
r2millers is offline
I also agree with the guys above. When my 4r100 tranny did the same and chattered like rumble strips, shifting into OD, I changed out the ATF. It didn't immediately fix the issue but after some additives, including Slick 50 tranny, and eventually, Lucas Oul tranny additive, the rumble finally went away.
I know many here don't recommend additives but it worked for me.
This was probably 10 yrs ago and it's never come back.
Old 05-02-2015, 10:19 AM
alloro's Avatar
alloro
alloro is offline
If it's shuddering then add some Lucas tranny fix to it. I didn't have an issue with my Navigator but it worked very well on my Mustang.
BigBad408
05-24-2016 09:02 AM
Nick 99 E350 v10
10-30-2015 08:13 AM
Towmanjbo
07-17-2015 07:23 PM
sunuvabug
1999 to 2016 Super Duty
01-05-2015 04:55 PM
pwalker64
29
09-03-2006 06:01 AM
Quick Reply: Need help with rear end vibration
