issues getting engine swap to run, help.
#196
#197
#199
Okay, so after doing some internet research, it seems like this is fairly common with AOD's, and it is usually to do with a stuck valve body and/or a stuck governor. Apparently if the transmission has been sitting for a while the aluminum in the valve body gets a bit tarnished and the valves don't work like they're supposed to. Anyone ever personally done this?
#201
#202
From What I read limp home mode is a function of a failure, controlled by the computer.
I have read about the TV cable being very senstive to adjustment. Since you did drive it without a TV cable, I am wondering if doing this screwed up the tranny. There isn't many options. Have you stopped by a tranny overhaul place and talked to the owner or supervisor? Many shops are being more helpful trying to get your business now or later. chuck
jburroughs12
26
04-23-2011 10:19 AM
joes52f6
11-11-2008 08:27 AM
