Northern Tools breaker bar 3/4"
I know its not the best but only going to use it a few times to remove a 30mm bolt thats has 405 ft lbs of torque. What do you think?
heres a link to it:
Grip-On Tools JUMBO Mechanic's Breaker Bar 40in., Model# 67330 | Ratchets + Handles | Northern Tool + Equipment
Thanks ~Gage~
heres a link to it:
Thanks ~Gage~
go with a 1" at 400 ft. lbs. your going to have to put some a_ _ into it.. use a pipe extension as well if you have the room..if you have a harbour junk around try them for the 1"....the 3/4"drive may twist off..
you might be able to buy a whole 1" drive set from H.J. and then sell it after...they aren't very much on sale....
I was looking at the Northern Tools one because its 40" long...Ya my problem is that I really should buy an Torque Wrench that will work for 400lbs. only one I found is a Snap On but its $480. What im doing is installing a lift kit and the track bolt needs 405torque and the pitman arm needs 350torque.
Thanks ~Gage~
Thanks ~Gage~
Benztechnc
02-04-2015 01:25 PM
Money-Pit
12-01-2014 08:40 PM
RabidJade
09-01-2013 01:09 AM
