help with tranmission 91 F350
Old 03-07-2011, 03:56 PM
rboyse's Avatar
rboyse
rboyse is offline
can anyone tell me what could be making my TP senors keep going out? i just put a complete rebuilt tranny (E40D) in it. and it is shifting hard and fast when the truck is cold shifts like a dream when it warms up shifts bad and my TP keeps losing what i set it at. PLEASE HELP
Old 03-07-2011, 04:30 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
When you check the trouble codes is the TPS the only one that comes up?
Old 03-07-2011, 05:00 PM
rboyse's Avatar
rboyse
rboyse is offline
nope not no more it was and we change it agin for a second time now it throws a code 11 means system is clear
Old 03-07-2011, 05:05 PM
rboyse's Avatar
rboyse
rboyse is offline
no codes right now showing all is clear
Old 03-07-2011, 05:18 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
When it shifts bad do the tach and speedo read steady and correctly?
When you fitted the rebuilt trans did you fit a new torque converter and a new range sensor?
Old 03-07-2011, 05:32 PM
rboyse's Avatar
rboyse
rboyse is offline
tach and speed are correct and new torque converter was put on. it was also dyno.
Old 03-07-2011, 05:49 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
Sounds like you did everything right. However if the trans goes into safe mode it usually means that the computer has detected a fault. It will also cause the overdrive light to blink to warn the driver that there is a fault. When this happens there should be a trouble code. There is a build date before which the computer does not store transmission codes and I can`t remember if it is around `91. If it is then simply by switching the truck off you may be clearing any transmission codes.
Maybe try getting the transmission codes after the fault occurs but before switching the key off.
Hopefully some of the trans experts will give an opinion soon.
privateer, eh
437
01-25-2024 03:55 PM
wilevel2
07-07-2009 04:24 PM
GVGaston
06-12-2006 09:40 AM
FE427TP
01-07-2002 08:54 AM
Quick Reply: help with tranmission 91 F350
