Wheel Bearing 2005 4 x 2 Front
I need to replace the front passenger side wheel bearing and I am unsure of the breakdown and would rather have the part in hand before I tear it down. Some places show an assembly and some show just the bearing. I was quoted $250 by a shop but if its fairly simple I'd rather do it myself. I changed the rotors and brakes a few years ago so I know how to tear it down, just don't know where to find the bearing and how to get it off. Remember this is a 4 x 2. If anyone has advice or a parts breakdown that would help alot, thanks!!
Joe
Joe
Joe
Joe
It is a sealed bearing, very simple job. If you had bought the rotors from Autozone, they would be giving you a new one for up to 2 years.
bearing
So pop the rotors off and the bearing should be right behind them? All the parts places show a sealed bearing, does it just pop off or will I need a puller? This is what Autozone shows Duralast/Wheel Bearing - Front (DL517014) | 2005 Ford F150 1/2 ton P/U 2WD 8 Cylinders W 4.6L EFI | AutoZone.com
Durlast Part #DL517014
Thanks!
Thanks!
the rotor and bearing on 2 wheel drive are a sealed unit you cant just change the bearing.need to by new rotor also the nut holding it on needs to be replaced one time use only around $25 at dealer and they need to be Torqued to 296 foot pounds. and you should change rotors in pairs as there 2 years old.or the breaking won't be even it will pull to one side
Still confused
John, how did you get the old one out and get the new one in? I am trying to have a plan before I tear it apart and all the places say different things!
xlt, all the local parts stores show a single bearing, not one in the rotor.
How is this bearing held on? I am just confused, thanks for any help!
Joe
Joe
Do you really understand, that even at Autozone, you are going to pay $60 for the cheaper front wheel bearing warrantied for 1 year,plus a $19 spindle nut that needs to be replaced every time you take off the rotor verses a new rotor with a new wheel bearing with a 2 year warranty for $85. and no messing with the bearing ???
