1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Stripped water pump T housing threads
Old 03-02-2011, 01:16 PM
ArtStream's Avatar
ArtStream
ArtStream is offline
Question Stripped water pump T housing threads
Hey you Powerstroke geniuses!
I've been learning all sorts of great repair tips and procedures from you folks over the past few months.
Thank You.
I recently replaced my T-stat during a flush, when I backed out the 3 bolts, one was difficult backing all the way out. Inspection of the bolt showed aluminum in the bolt threads. I cleaned the bolt and reassembled the T housing. I cleaned all mating surfaces and with fingers crossed torqued to 10 flbs.
It's has held for about 600 miles and is now leaking.
I've read all the posts on leaking t-housings.
I'm thinking I'll need to tap or something. I'm on the road and have 2,000 miles ahead of me.
The Water pump threads go completely through the flange, could I put in a longer bolt and use a nut ?
I'm not far from Yuma, so I could get to hardware and auto parts stores.
Is the nut and bolt idea viable?
Any Ideas?
Thanks you guy's
FTE rocks...
1998 E 350 TDI, cut away van.
Old 03-02-2011, 01:20 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
If the hole passes all the way threw and the room is there a nut on the back side will be perfectly fine.
Old 03-02-2011, 02:49 PM
ArtStream's Avatar
ArtStream
Bolts
Thanks Snowseeker.
The truck is still drivable for a short hop into Yuma.
I'm afraid to touch the housing bolts till I have a longer replacement and some RTV and some nuts.
Given that, would you know or anyone what size bolts (thread size)
they are, I'll just add 1/2 for the bolt?
Thanks SS
PS, I have friends in Big Flats, WI!
Old 03-02-2011, 03:15 PM
Snowseeker's Avatar
Snowseeker
I don't know personally but in a search I found 6x20mm coarse thread. So 6x30mm should work out nicely. personally I would try and get stainless hardware, it normally isn't much more in price.
I agree, don't touch the bolts until you get the longer ones.
NotSoSporty98
08-14-2016 12:53 PM
44nneedit
12-18-2015 03:34 PM
BBslider001
09-11-2015 09:43 PM
Epd444
24
05-22-2012 11:32 AM
BlackJeep
04-30-2008 06:06 AM
Quick Reply: Stripped water pump T housing threads
