Applying Por 15
Brush it on. It will even out. Make sure you follow all of the directions exactly as they are posted. Start with a quart. It goes a long way. Keep it off your skin, wear nitrile gloves. It does not come off. Get a bottle of their remover/thinner.
You can spray it but, the area should be very well ventilated and wear a mask. I've found that lacquer thinner will work ok for clean up, use their product for spraying. I used less than a quart on our 70 frame - cab back- springs and differential housing.Brushing it on - it does flow real well. Gloves are a must and make sure your hands are free of that stuff before going to the bathroom.
POR 15 isn't perfect, but it is much better than Rustoleum. I used Rustoleum on my frame. 6 months later I had to redo all of the work including re-sand blasting, as the Rustoleum peeled off. I applied POR 15. That was 6 yearsw ago. It is still there.
I accidentally set a can of POR 15 on my garage floor, that was leaking. Came back the next day and couldn't remove it. It was there for quite awhile. Ended up having to use a sledge hammer to remove it.
I used POR-15 the first time on a Datsun Z car I played with ten years ago. The current owner does not have a garage and it still shows no signs of rust. Try that with your Rustoleum.
Yes, on any part that sees the sun, apply a top coat of paint to protect from fading.
I disagree, I've had better luck with Rustoleum & it is a lot cheeper. I've used that expensive crap on frames, etc & like Rustoleum it (didn't) peel off but is dulls out and chipps easily. IMO there is no justification as far as I'm concerened to pay that much for a product that isn't any better. You all can brag it up till the cows come home. I'll never change my opinion of it & I won't recomend it to anyone for anything, not even a garage floor.
We did the frame on my brother f250 2 years ago. Used a needle scaler to take the rust off, then a heat pressure washer to"clean" the frame, then the marine clean, then brushed on the POR15. In less than 6 months there were brown speckels coming thru the POR15. Granted this truck is driven in the salt belt(NJ) but i have done paint jobs(rustolium) on less prepared frames and they lasted ALOT longer in the same conditions. with only $20 bucks in material and not $200+ like the POR 15
I am going to try Chassis Saver next time, hopefully that works better than POR 15
