Valvetrain help
Valvetrain help
I have a 1997 351w engine I am rebuilding. I put a new Comp Cams cam in (off the top of my head I think it was 35-349-8), everything else is stock. After installing the lifters, pushrods, and rockers and torquing them to spec. The rockers (at bottom travel) all seem to have excessive play. I know the lifters can bleed down and cause this, but looking at them, they appear to have their plungers all the way up. I'm panicing here......... I was supposed to be putting this in next week, and my budget is dwindling fast!
Do I need longer pushrods?
If you need some different length pushrods you can find them pretty reasonably priced if you shop around.
Yes, the distance between the top of the valve and the rocker arm. Do yourself a favor and check this NOW, so if for some reason the engine doesn't run right you will know this is not the problem. Make sure the lifters are completely bled down. The Haynes manual I have does a pretty good job of describing the procedure. If you have a Chiltons, it probably would too.
If you find you need some different length push rods, I think the rocker arm ratio is about 1.6 to 1. As an example if you changed the push rod length by .030, it would change the clearance by about .048.
I have my original engine that spun a bearing at home (this engine is at my work) I am going to bring in the valvetrain from that and see if the results are the same. I will check the clearance, but it confuses me how it could get this way. The Cam shouldn't have mad a difference. This was a salvage yard engine my job purchased for me because I plow our lot. I ring & bearing'd it, with the new cam. The only thing I can think of, is... it was like this due to worn rockers or pushrods, or lifters, because I just tore it down, didn't check them.
Thanks for your help. I'll let you know what my clearances where on Monday when I come back to work.
I checked the worst valve so far, and there is about .032 of clearance (with the lifter primed)
I primed the engine until oil cam out of the rockers, then turned the motor over by hand, while priming. The checked and several pushrods still have play.
Is there some kind of cap that belongs on top of the valve, between the valve and the rocker? I've seen that on other engines, and want to make sure I'm not missing something obvious!
FossenRacing
10-02-2014 01:29 PM
72ford360
12-07-2004 01:48 AM
Ringo Fonebone
06-10-2004 07:17 PM
HangGlider
06-23-2003 11:56 PM
Jsbiohazard
04-10-2003 07:37 PM
