taillight wiring diagram?
Old 02-20-2011, 01:16 PM
crestfallinman's Avatar
crestfallinman
crestfallinman is offline
ok so i took the bed off last fall and went over the frame and such, and had trouble with the taillights
the previous owner decided he was going to splice in all new wiring and well he made it all the same color
so i was going to get 3 different color wires and rewire it the right way, solder together and heat shrink it
does anyone know of a wiring diagram for this harness to take out the guess work of hoping the colors are right?
the way the po botched it in i am having trouble figuring out where to begin
Old 02-20-2011, 01:26 PM
ri_truck_guy's Avatar
ri_truck_guy
ri_truck_guy is offline
Orange/Light Blue = Left Directional/Brake Light
Light Green/Orange = Right Directional/Brake Light
Black/Pink = Back Up Light
Brown = Running Lights/Plate Light
The following users liked this post:
Old 02-20-2011, 01:27 PM
crestfallinman
thanks so much i really appreciate it
Old 02-20-2011, 01:33 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Old 02-20-2011, 01:45 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Full-size wiring diagram image here, don't let your browser shrink it on you:
http://img20.imageshack.us/img20/3310/pg7fullsize.gif
Old 02-20-2011, 02:15 PM
crestfallinman
perfect, i just went down to get the wire and now im mapping out which colors to put where, thanks to all!
Old 07-21-2012, 10:30 AM
ROCKYTULSA's Avatar
ROCKYTULSA
ROCKYTULSA is offline
not to bring back the dead but this thread just saved me !!!
Old 04-01-2016, 03:52 PM
Chris smallpiece's Avatar
Chris smallpiece
Chris smallpiece is offline
somewhat helps me, im still trying to figure out which wire goes where on the brake switch, i have a solid green and a green and i think red wire, i took the wires off to replace the ends and i forgot to take a picture to put it back together :/
Old 04-01-2016, 04:02 PM
ryry46d9's Avatar
ryry46d9
ryry46d9 is offline
this is out of a 86' F150 with a manual upside down even
Old 03-04-2020, 10:15 AM
Dakota Hollister's Avatar
Dakota Hollister
Dakota Hollister is offline
Tail light harness
So recently I just bought a 1987 f350 4x2 custom. When I bought it I knew it needed a gas tank a bed and tail lights but under further investigation when I got home with it I can seem to find where the wires are ran from so I was wondering if it would be easier just to buy a new harness and swap it out if that was possible and i am most likely gonna make a flatbed out of wood and metal
Old 03-04-2020, 04:11 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,108 Likes on 1,796 Posts
Welcome to FTE.
FYI you did not post this in the right area as this is for the 80 to 86 but they should be close I would think.
Now the guess on my 81 F100 and pretty sure all the 80-86 trucks have 2 harness out back.
1 Starts under the brake booster assy. where the main harness comes out thru the fire wall and plugs into a harness that runs down the frame rail to the rear.
This comes in different setups based on fuel tank or tanks.
Then you have the tail light harness that plugs in to the rail harness at the left rear corner.
Should be 5 wires IIRC, left turn/brake, right turn/brake, running lights, back up lights and a ground.
(my truck did not have the ground wire for my year so only 4 wires)
So knowing that and depending on how far back you need to go to get to good wires it might be best to just run new wires.
If you have a trailer parts store near by they should have bundled 4 or 5 strand wire for rewiring trailers that you might be able to use?
I was missing the plug and taillight harness on my 81 F100 Flare Side but I was also using full wiring harness from my 81 F100 Style Side parts truck.
The tail lights are different between the 2 trucks so I had to make a taillight harness from the parts truck harness to fit my Flare Side.
From this
To this
And the plate light harness
Dave ----
Old 03-04-2020, 08:54 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
The connectors changed in 1987 and the two generations aren't plug-and-play but they're the same basic concept that Ford has been using for decades.
Stock replacement harnesses aren't available but there's aftermarket, e.g. Painless.
Yeah, as Fuzz said, the wires poke thru the firewall down by the brake booster, down the LH frame rail to the transmission & rear end. There are some HVAC-related things poking through on the passenger side, too.
Old 05-06-2021, 11:53 AM
Crazy Krasus's Avatar
Crazy Krasus
Crazy Krasus is offline
I have a 94 and the pig tail that the tail light harness plugs into is fried I wanna hard wire it because I can't get a new pig tail the harness on the frame rail has 7 wires and the tail light harness only has 5 wires
Old 05-06-2021, 05:26 PM
FuzzFace2's Avatar
FuzzFace2
Your 5th wire is a ground that is not listed in the above post.
As for the other 2 wires is the truck set up with a trailer tow package?
If so it may have a wire for electric trailer brakes (blue most of the time) and a 12 volt to charge a battery on the trailer (red most of the time).
I have seen different weather tight pig tail connectors at NAPA and think I would go with that if I had to pull it apart again.
Dave ----
wtx66f100
10-20-2014 12:46 PM
1990f150dude
04-28-2012 06:17 PM
FLJ
Electrical Systems/Wiring
06-20-2009 06:47 AM
mds01
1978 - 1996 Big Bronco
06-29-2003 02:05 AM
77hiboyboy
05-15-2003 09:29 AM
Quick Reply: taillight wiring diagram?
