When I set the parking brake the indicator light on the instrument panel doesn't come on. It lights up at the initial startup, but when brake is set doesn't light up. Any suggestions?
WD-40 is a lubricant not an electrical contact cleaner. So although it might make the switch slide smoother, it can prevent electrical contact. Try spraying some carb cleaner up at the switch to get the WD-40 off. It's possible the switch is bad, but I've never seen one go bad.
