Misfiring 2005 3.0l Ranger
I'm working on a 2005 3.0l 4x4 Ranger and I am having trouble figuring out my misfire. The codes say:
Misfire detected at start up (within 1000 rpm)
Cylinder 2 misfire
Cylinder 5 misfire
The truck has 103,000 miles on it, and the spark plugs, wires and coil are all new.
The idle seems rough, and when I am driving, the check engine light stays on, but occasionally it will flash, and when it is flashing the truck has no power (it will rev out of gear.) After around 30 seconds the light will stop flashing and the truck will regain its power and accelerate like normal.
Any suggestions?
Cylinder 2 misfire
Cylinder 5 misfire
Any suggestions?
few possibilites
i ran into this problem check the fuel injector prongs one could be bent over not getting contact allowing a miss. Possibilties could also be coil packe or yours mave have distributor you should replace rotor button cap and points. Double check wires but you probably dont have them switched over.make sure plug wire is not touching manifold or header causeing an arc which this will make it miss. injectors also could be bad let me know if this dont work gusbus93@aol.com.
Cylinder 2 misfire
Cylinder 5 misfire
Any suggestions?
Cylinder 2 misfire
Cylinder 5 misfire
Any suggestions?
I own a code reader. if that was my truck I would see if I could catch a pending code? ie. camshaft sensor
* a flashing cel indicates multiple misfires and that your CAT is in danger.......it is not a good idea to drive with a flashing CEL
did you have the same codes before you changed the plugs and wires? what plugs and wires did you use? did you gap them correctly? have you tried adding Techron to the tank? you should clean the MAF and check the airfilter and air intake...
I do not own a reader, but there is an O'Reilly's right down the street, so I can use their reader. I just don't know how to check for pending codes.
One thing I should add is that before the new plugs/wires the truck threw a "System lean bank 1 and bank 2" code, but that hasn't shown up again since the tune up. I'm gonna mess around with it tonight and see if I can figure anything out.
Thanks for the help so far!
Some of the '05 models w/3.0L can have exhaust valve issues: Ford Truck Enthusiasts Forums - 2005 Ranger 3.0L head replacement
Definitely pull the codes. The lean bank 1 & 2 can be caused by a dirty MAF, or an actual lean condition. Cylinder 2 & 5 share the same coil. If one had a problem, the other may just be along for the ride. Did you get the dual 'stuff' plugs? One plug fires normally, and the other fires from outer electrode to center electrode, more or less in series.
tom
tom
So I finally figured out my problem. I kept driving the truck and messing with it, and finally I took it to the local Ford dealership, paid them $80 and they did a full diagnostic rundown on it. The found the 2 cylinder had a 5% drop in compression, and another showed a very slight loss.
I finally accepted reality and pulled the heads. Pretty much all of the exhaust valves had receded into the head, the worst being about 2mm. They are currently at a machine shop right now getting hardened exhaust valve seats put in, along with a full valve job. I am dreading putting it all back together, but I hope it will finally solve my problems with the truck.
Thanks for all the help!
quote: "The found the 2 cylinder had a 5% drop in compression, and another showed a very slight loss. "
From what I have read, the results of a compression test are 'there is a problem when the pressure difference between two cylinders is > 10% "... or words to that effect.
A 5% drop is not out of tolerance, in other words. At 140 psi, 10% would be 14 psi, 5% would be 7 psi. The numbers in the book, so to speak, seem to allow a LOT more.
Maybe they picked a percent out of the air???
I had read there was a problem with the Vulcan doing exactly what you report, sorry to say. Glad you got your problem pinpointed.
tom
tom
thegreatgate
1997-2006 Expedition & Navigator
09-29-2015 09:10 AM
