2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Spark Plugs
Old 02-14-2011, 02:08 PM
fusionsp's Avatar
fusionsp
fusionsp is offline
Spark Plugs
Been reading a lot about the plug issues and was thinking of replacing mine @36k before I get too much mileage and hoping they will be easy to remove now. If not, my local part's store has the removal tools.
Will I have the same problem if I use new Motorcraft plugs or did they redesign because of this issue ? I've read that Champion has a 1 piece plug but not sure how well they perform. I never thought Champion made a good plug (in the past) compared to Bosch, etc.
Thanks
Old 02-14-2011, 08:15 PM
fusionsp's Avatar
fusionsp
fusionsp is offline
The Best Spark Plugs for a Ford 5.4 Engine | eHow.com
Just found this article. Looks like Motocraft did beef-up the 5.4 plug.
Old 02-14-2011, 08:49 PM
MCDavis's Avatar
MCDavis
MCDavis is offline
Regardless of the plug design, you'll find that your 5.4L will perform the best with the Motorcraft plugs in it.
The F150 guys that have put in Champion and other brands have found that after a few thousand miles they are having sputtering and hesitation issues, amongst other things.
I, and a lot of the truck guys, will recommend you stick with the Motorcraft plugs. You shouldn't have too much of a problem with an 07+ Expy as Ford had pretty much caught on by then and made a fix. You're not likely to break of 6-8 of them like the 04-06 F150 guys.
Old 02-14-2011, 09:36 PM
TheThickster's Avatar
TheThickster
TheThickster is offline
As far as I know the main problem was carbon build up, to much carbon seizing the spark plugs.You could seafoam every oil change to help knock off some of the carbon, or IIRC you could get a can of carbon buildup remover from the dealer.
Old 02-25-2011, 05:47 PM
fusionsp's Avatar
fusionsp
fusionsp is offline
Just got done removing all 8 and didn't break any. Took my time and soaked each one with carb cleaner after loosening. All I need to do now is figure out which Motorcraft plugs to use. My dealer quoted me $26 each!! Not sure if I need to go with the SP507 or the SP509 plug from Motorcraft. Anybody know the new part#?
Thanks
Shawn
NewXer
2009 - 2014 F150
02-27-2014 06:51 AM
MarcusBear
3.8 & 4.2L V6
28
12-17-2011 02:26 AM
97F250XLT
1999 to 2016 Super Duty
01-22-2010 08:10 AM
kidoo
09-28-2003 08:02 PM
TallPaul
15
11-15-2001 08:14 AM
Quick Reply: Spark Plugs
