How can I repair my holley???
I was driving to the store today and on the way back I noticed a strong gas smell. I went back home, opened the hood, and saw gas dripping under my air filter! Took the filter off, I thought the line wasn't screwed in tight, but when I wiggled it the whole thing just fell off! It seems like the previous owner just had it pushed on there.
What would be the best way to fix this, without buying a new carb? Would JB Weld work? I really don't have the cash to buy a new one right now!
While you are at it, I would probably buy a gasket kit for it. I rebuilt a 600 double pumper on my maverick with a Holley "quick kit" that i got from o'reilleys for about 35 bucks. There are also rubber o-rings on the transfer tube that should probably be replaced as well. Those should come with the kit.
Ok, I'll buy the gasket kit too. I'm searching for the bowl now, without knowing the model #, this one looks like it: Holley 134-101 - Holley Fuel Bowls - Overview - SummitRacing.com
Will it work? Also, I've never rebuilt a carb before, what problems will I run into when I take the bowl off?
Also, the good thing about buying the holley kits is they usually come with blue non-stick bowl gaskets which makes things alot easier if the bowls ever have to come off again for anything in the future.
Look under that black air cleaner spacer.
But....now I'm having a problem with the fuel pump not shutting off(I started a new thread)!
Danny Stroup
27
11-15-2011 10:04 PM
