Sound systems for your truck...
#46
Many of the better quality speaker systems, Boston Accoustics Pro SE for example, have seperate tweeter mounts that make it a rather simple task to mount the tweeters virtually anywhere on the dash or above. If you personally find that impractical then you could always leave the tweeters attached to the bass/mid driver and mount them as a unit in the door or kickpanel. On my DD the tweeters are factory mounted in the door handle assembly...it brings the high frequency driver up closer to eye-level and improves the spacial imaging. This is why I started this thread in the beginning...to see if anyone here had gone through a professional sound system installation and could share their experience/design. I am still about 6 weeks away from building my system so I thought that I would start the discussion.
#48
That would mean they would have to be in the windshield posts or at least above the windshield corners. Not very practical location. So if you can't place them there, is there a major loss of sound quality if I move them lower and aim them back at the passenger area?
I realize where optimum location is but where is a practical location without spending a zillion dollars on trick stuff?
jim
jim
Would that be an acceptable solution? (Not only for you, I am also asking for a logic check from the experts.)
sowaxeman
09-10-2009 07:14 PM
caa1571
05-20-2002 10:46 PM
