npi intake ?
Old 02-09-2011, 03:38 PM
scott9320's Avatar
scott9320
scott9320 is offline
Smile npi intake ?
ive got an early 99 superduty, 4/98 on door sticker. when previous owner ( my uncle) still had truck 5.4 went south at 315,000. he found a replacement 5.4 out of a 00 model (i think) and it was swapped out. now i helped some on swap but wasnt there for all of it. got curious today and looked at the 5.4 thats in the truck now, was curious if it was a PI or not. i got lucky, it has PI stamped on head. but the intake is cast instead of plastic. was any of the PI's built with cast intake or during the swap did someone change out the intake, i asked everyone that was there but nobody seems to remember doin it (go figure). if its not a PI intake from what i understand after doin some searchin here if i swap it for a PI it will improve power ? now im not expecting no nitrous shot feel here...jus a lil improvement. will my throttle body and all the other gadgets on my current intake swap to a PI intake...or do i need a complete intake.
btw.....the whole intake is cast, not jus the coolant crossover.
Old 02-09-2011, 06:16 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
The '99 intakes on F150's were still AL, they are somewhat desirable since Ford went to plastic on the PI intakes after that.
So in short yes there was 1 year Ford made AL PI intakes.
Old 02-09-2011, 06:25 PM
phil6608's Avatar
phil6608
phil6608 is offline
Yeah,
you've got the best intake out of all of them.
It's definitely a keeper!
scott9320's Avatar
scott9320
thanks galaxie641........is there anyway to tell if its a PI intake by outward appearance.......and could someone have swapped the NPI intake on it while they were swappin engines.....or will the NPI even fit the PI heads
Old 02-09-2011, 06:29 PM
scott9320's Avatar
scott9320
phill6608.....thats good to know.....usually i end up with the worst design on any ford truck ive had......for once the engineering gods has smiled at me....lol
Old 02-09-2011, 06:34 PM
scott9320's Avatar
scott9320
now i have another thought.....the truck is still runnin on the NPI programming on the ECM.....would it be worth havin it reflashed or is there any difference between the NPI and PI ECM program
Old 02-09-2011, 07:12 PM
phil6608's Avatar
phil6608
phil6608 is offline
A custom tune is always beneficial.
If you got a custom tune on a SCTX3 you cold load it in your truck and it should make a nice power increase.
flyingtexan
Modular V8 (4.6L, 5.4L)
12-21-2016 02:20 AM
chloichina
1997 - 2003 F150
06-26-2013 03:28 PM
chloichina
06-26-2013 03:00 PM
Quick Reply: npi intake ?
