Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-09-2011, 12:10 PM
Captain65 Captain65 is offline
Garage is empty, add now
Captain65 is starting off with a positive reputation.
Beach Driving - 2007 Expedition 4x4
I am considering going to Carova Beach in the Outer Banks for vacation. To get to the rental house, we will need to drive on the beach. Does anyone have any experience drving a 2007 Expedition 4x4 on the beach? I understand the sand can be soft on Carova Beach, so I am wondering how the heavy Expedition will do.
  #2 (permalink)
Old 02-09-2011, 12:56 PM
RSCHAP1's Avatar
RSCHAP1 RSCHAP1 is offline
RSCHAP1 is starting off with a positive reputation.
Just run the tires down to 8-10 lbs or so.
I took my 1998 and my 2004 to sand dunes and had no troubles.
Stock size and close to all terrain pattern tires on both.
  #3 (permalink)
Old 02-09-2011, 03:51 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MmmmmmKayyyyy
2006 Ford F-150
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
8-10 psi is WAY too low. You'll be fine in the Expy, and you may not even need 4wd depending on where in Corova you are. Most of the "streets" up there are packed sand. There is off highway access right on the shoreline where you can get into some soft stuff, but you'd be fine around 20psi honestly. If you run 8-10psi as suggested, then you increase the likelihood of rolling a bead off the rim. That's a good way to ruin your vacation.
I suggest 20psi. Constant forward momentum in anything that appears "soft" and take a recovery strap if you're really concerned. The nice thing about the Outer Banks is that someone will always have a bigger truck than yours down there, and most of those guys are willing to strap you out.
__________________
Chandler
Official Slackmaster #24
  #4 (permalink)
Old 02-10-2011, 08:56 AM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
Check Wally Mart's fabulous automotive department for a small plug in air compressor. They're like $15 or $20 and would be just perfect for airing-up after you hit terra firma again.
They're also great for inflating rafts & beach toys!
__________________
1997 F250HD 4wd, 460-5-speed Ext. Cab, Blue
2007 Navigator L Dark Blue Pearl
2003 Mercury Marauder, Dark Blue Pearl, Trilogy Supercharged, 13.1 @ 105
  #5 (permalink)
Old 02-10-2011, 09:13 AM
MCDavis's Avatar
MmmmmmKayyyyy
2006 Ford F-150
That's not a bad idea, but if IIRC there is a service station right where the beach access is that has free air also. But always good to have a backup in case their compressor is down.
Just FYI, I'm a VA Beach native who vacationed in that area quite a bit. We used to surf fish in Corolla before the major house expansion took place. I still make it down there for surfing trips, usually further south to Hatteras, but regardless you'll be ok in the Expy! Whatever you do, use common sense.
__________________
Chandler
  #6 (permalink)
Old 02-13-2011, 10:39 PM
680276122 680276122 is offline
680276122 is starting off with a positive reputation.
Every year I take the family on the sand there at the Outer Banks as a good change to just sitting on the beach. I don't lower my pressure and have no problems. I typically travel closer to the water where the sand is harder. Recommend 4x4 high while on the sand. Toughest part is getting on/off sand as people are traveling too slow and end up getting stuck because they get out of the tracks. Enjoy.
Tags
4wd, 4x4, area, banks, beach, driving, expedition, expeditions, exxpedition, ford, ltx, mexico, michelin, obx, outer, sand
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
