6.9l diesel transmission options
my 85 f250 has the 6.9l diesel 4x4 and currently the 4speed manual transmission which sucks for the highway, is there ant other options for transmissions that will fit this application? i was thinking about going to an automatic but cant decide what would work better for me. i dont do any heavy pulling so the low low gearing isnt really needed
Your only option for a manual tranny would be the zf 5 speed. It has overdrive, but it has to come from a 7.3 diesel, since the zf has the bellhousing made into the tranny.
You could buy a overdrive unit and add to the rear of your tranny or the transfer case, but these are expensive.
Your only option for a automatic with overdrive is the E4OD. These usually need to be rebuilt with improved parts so they will hold up, and then you have to buy a computer system to run them, or get the factory computer system off a f250/350 from around 89-early 94 that had the diesel idi like yours and the E4OD tranny.
I put the zf in my 89, and am very happy with it. It gave me 3 more mpg on the highway, and it's much quieter with the lower rpms.
on
To add ...
The ZF must be from a Diesel 4x4 or F450.
And yes it will bolt right in with Ford parts, however you need to ensure you get the required parts to do the conversion.
4th gear in the 4spd is direct
5th gear in the ZF is .76
ZF S5-47
1) 5.72 5.08 4.14
2) 2.94 2.61 2.37
3) 1.61 1.53 1.42
4) 1.00 1.00 1.00
5) 0.76 0.77 0.77
R) 5.24 4.66 3.79
ZF S5-42
1) 4.65 5.72
2) 2.60 2.94
3) 1.53 1.61
4) 1.00 1.00
5) 0.77 0.76
R) 4.35 5.24
BW T18
1) 6.32
2) 3.09
3) 1.69
4) 1.0
R) 7.44
BW T19
1) 6.32 5.11 4.02
2) 3.09 3.03 2.41
3) 1.68 1.79 1.41
4) 1.00 1.00 1.00
R) 6.96
NP 435
1) 6.68 6.68
2) 3.34 3.34
3) 1.66 1.74
4) 1.00 1.00
R) 8.26 8.26
-Enjoy
fh : )_~
ZF S5-47
1) 5.72 5.08 4.14
2) 2.94 2.61 2.37
3) 1.61 1.53 1.42
4) 1.00 1.00 1.00
5) 0.76 0.77 0.77
R) 5.24 4.66 3.79
ZF S5-42
1) 4.65 5.72
2) 2.60 2.94
3) 1.53 1.61
4) 1.00 1.00
5) 0.77 0.76
R) 4.35 5.24
BW T18
1) 6.32
2) 3.09
3) 1.69
4) 1.0
R) 7.44
BW T19
1) 6.32 5.11 4.02
2) 3.09 3.03 2.41
3) 1.68 1.79 1.41
4) 1.00 1.00 1.00
R) 6.96
NP 435
1) 6.68 6.68
2) 3.34 3.34
3) 1.66 1.74
4) 1.00 1.00
R) 8.26 8.26
-Enjoy
fh : )_~
The different number/ratio columns I believe are for gas versions or diesel versions. Looks like the 1st column is the diesel versions.
A 6 speed will not bolt in. It has a larger output shaft, so it requires the later model transfer case, and then you have no place to hook your speedo. And I believe the front clutch area requires modification to fit also, but I have forgotten all those changes required. Too much work for what you get, which is just a extra gear in the middle.
on
Columns are available gear packages ...
The difference between the S5-42 and S5-47 is input strength.
S5-42 = 420 (440) lbs torque. (580 / (600) Nm)
S5-47 = 470 lbs torque. (640 Nm)
Don't think the S5-47 provides any speedo hook up at all, where some models of the S5-42 do.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
transmison,
the zf5 is good for a trans but a bit small for a 7.3 idi. mine is geared low, if i have to stop at a light, i make it to 4rth before get across and almost running red. top speed is 50 on 4:10.
what i need help with is figuring out transmission will fit this truck and the best option. needing at least 4 more gears and leaning towards finding a 13 speed. 18 would be a bit much. but i use this truck for work and travel over 10k miles a month and alot of times loaded or pulling. i get great mileage 20 plus if i can just make it to point b it would be nice. this engine is sound, just need some gears behind it to make it move and climb grades. its not uncommon to be finding 30 percent grades or better in my line of work. i dont care about firewalls, floor pans. i am already at 4.5 tons empty and 6 tons when loaded so the extra weight of trans is not a issue, plan on putting in 2 ton axles. also truck is 4 wheel drive so would like to keep that. i dont care about a different clutch setup as my firewall is already blown out and needing extensive repairs from metal fatigue. advice or directions on where to look or dig would be nice.
i know ford made a trans that was a 9 but could be made into a 13 that was in 4x4 medium duty applications for a 7.3idi. plenty of people talk about them but no one knows a name.
i know theres options but no one gives these trucks credit nor wants to talk about them.
You are correct, take the Ford bell adapter off, put the SAE adapter in its place, and you can run a heavier duty trans. They are large, heavy, and even noisier than the zf with no DMF flywheel, but you will get more gears. Your 4x4 may be a problem though unless you go to a divorced setup.
Mr.FordMan
09-01-2017 03:43 PM
FordMan1981
05-20-2017 05:31 AM
tyler.dunn94
07-01-2016 05:57 AM
tyler.dunn94
18
06-20-2016 05:22 PM
1986, 69, 69l, 73, 86, diesel, f250, fit, ford, manual, trannsmissions, tranny, transmission, transmissions, truck
