Need step by step instructions for truck revival
Got a 99 super duty that’s been sitting in a field for 5 years. I need step by step instructions on how to prepare to start it and get it running again. Here is my thought process, please edit as you see fit:
Check oil - done. Is full and looks fairly clean.
Clean out radiator with garden hose- run until water is clear, fill radiator.
Replace thermostat
Replace fan clutch
Put 10 gallons of fuel in with seafoam (tank is empty)
New battery
New spark plugs
Pour a capful or marvel mystery oil down each spark plug hole
Attempt to start
Thoughts?
Replace thermostat
Replace fan clutch
New battery
New spark plugs
Attempt to start
Thoughts?
These are not 50 years, don't worry. Check out what you mentioned and crank 3 times for ~7 seconds directly at the starter (key off) to built up base oil pressure.
"Pour a capful or marvel mystery oil down each spark plug hole"
This is too much if you reinstall the spark plugs again. Let the engine crank without spark plugs. Reinstall it, and let her fire up.
Denny
If you are just trying toget it started don't worry about the coolant until you get it to start, after you know it will start and run then do the coolant. But if has no antifreeze in it where did it go? Was it drained or did it leak out? And the biggest question is why was it parked to begin with? If it was me I would pull the belt, change the oil, look at the plugs, fresh gas and maybe a little oil in the cylinders and try to get it to run and then worry about everything else, if it won't run everything else is a waste of time.
Denny
Denny
I see what you mean. Previous owner told me it was overheating and had low oil pressure (according to dummy gauge I’m assuming). He said he pulled manifold (intake or exhaust I have no idea) and saw some sludge, so he decided it was gonna be too hard to fix and abandoned. So, coolant gone due to overheating and sitting for five years i’m assuming. Does that change the way you would approach? Someone told me I should change oil, but fill with half oil and have diesel fuel and allow it to run for a bit to clear out sludge. Does that sound right ? Or would a bottle of seafoam with oil have the same effect?
Denny
What motor are we talking about?
Without the belts all you will hear is the motor and nothing else plus you won't be turning over the dry water pump. The motor can run for a few minutes without any coolant without any problems. I'm trying to have you get it started with the least amount of $ so if it dosen't work out you will be out less $ but if it does work you can just continue hooking things up and spending more money.
Denny
Denny
