Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Today's Posts VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 02-02-2011, 05:50 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
Garage is empty, add now
2006powerstroke90 has a very good reputation on FTE.2006powerstroke90 has a very good reputation on FTE.2006powerstroke90 has a very good reputation on FTE.
How much fuel do I use idling?
Well I usually let my truck warm up for about 20-30 minutes before I leave for work in the morning and before I leave work to go home.
Some people say I am crazy for leaving it out there running for that long wasting fuel....
I really don't think I am using that much?
How much would I burn per hour?
__________________
Tyler- I once owned a 2006 6.0 PSD, now drive a 2006 Dodge Cummins, and work for Chevy.
  #2 (permalink)
Old 02-02-2011, 06:15 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Several folks have done some testing in the past.
What I have seen posted is 0.8 gph at regular idle and between 1.1 to 2 gph at high idle (1200 rpm).
Some people argue it is less. Who knows ..............
I think these are in the "Ball Park".
__________________
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
  #3 (permalink)
Skill_Kills's Avatar
Skill_Kills Skill_Kills is offline
2002 Ford F-350
Skill_Kills is starting off with a positive reputation.
on the 6.0s its about a quart/hour
  #4 (permalink)
Old 02-02-2011, 06:19 PM
bismic's Avatar
Quote:
I would sure like to know where your info came from and how it was determined! I personally believe that is WAY too low.
__________________
Mark
  #5 (permalink)
Old 02-02-2011, 06:29 PM
2002 Ford F-350
Quote:
a buddy of mine was out of town and it was going to drop between 40-50 below and he didnt have anywhere to plug it in so he filled it up parked it for 9 hrs and only had to put in about 3 gals. so yeah about 1/3 gallon/hr. im sure it has quite a variance from truck to truck but he told me its in the manual somewhere as about a quart/hr (i have not read this so i cant verify whats printed)
regardless of what it actually is, its nothing to be worried about for 20-30 mins if it means your engine is nice and warm before using it.
  #6 (permalink)
Old 02-02-2011, 06:43 PM
bismic's Avatar
I pretty much have all the manuals and I can't find it in them (I could have missed it, but I do spend quite a bit of time in the manuals). Also, if your friend hasn't installed the harpoon mod, then there is no way to be very accurate in his test.
Also, Ford says don't idle for more than 10 minutes unless you have the high idle. I know folks that do, but you will generate more soot idling at 750 rpm's and it can eventually bite you.
Additionally it takes around 10 minutes of high idle to get your coolant up around 150 degrees F - when the weather is in the mid 20's. Regular idle is not very effective in cold weather at warming things up very fast.
__________________
Mark
  #7 (permalink)
Old 02-02-2011, 07:21 PM
amadas350's Avatar
amadas350 amadas350 is offline
2004 Ford F-350
amadas350 is starting off with a positive reputation.
i bet it is well below .5 gal.
our tractors have gauges that allow us to read fuel gph (and they are pretty accurate). and with 6.8L displacement, when idling it is reading .2-.3 gph. which come out to .94L, so i would say that skills_kills is pretty close.
idling for 9 hrs may not be good for egr, but beats the damage from coolant becoming frozen. but high idle mod is a definite plus in cold weather.
__________________
meahnical engineer
2004 F350 CC, 35 toyo's, arp studs, scangauge2, coolant filter, aero-turbine muffler, magnaflow exhaust, blue spring update, rhino lining, b&w ball hitch, fumoto valve, tank harpooned, high idle mod.
  #8 (permalink)
Old 02-02-2011, 07:22 PM
Frankenbiker's Avatar
Frankenbiker Frankenbiker is offline
Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.
frankenbiker
If you don't have a good "hard" drive after those long warmups, you're asking for trouble.
Idling that long will wash the lube oil off the cylinder walls, accelerating normal wear and hastening compression loss. Running at high idle will slow this process down, but not eliminate it entirely.
If you're not driving it hard enough to warm it up within 60 seconds of driving, stop idling it and plug it in overnight. And by "warm it up" I mean to have heat at the registers, which usually means 100 degree (or so) coolant temps.
The "industry accepted" standard is one gallon per hour. Observational evidence on my own Detroit Series-60 engine suggests half that. And the Detroit is a 12-liter engine.
At the current price of $3.50/gal, how much MONEY are you wasting?
Maybe enough to pay for that coat to keep you warm? *snicker*
-blaine
__________________
Tonka: 2007 F250 PSD 4x4 FX4
Gearhead Perf. Street Race Lite (vroom vroom vroom) - Factory Audiophile with sub (thump thump thump)
Rawson Koenig Toolbox (tools tools tools) - Colibert Rail Rider sliding gooseneck hitch (tow tow tow)
Ranch Hand Legend Bumper (stay outta the way!) - Bilstein 5100's (control control control)
  #9 (permalink)
Old 02-02-2011, 07:25 PM
bismic's Avatar
-blaine
Well said Blaine. I can buy down to 0.5 gph, but not less than that IMO (still admit I could be wrong). Comparing it to other diesels is not really applicable (EGR systems now and different injector functioning more sensitive to oil temps).
If you keep the proper coolant mix, I don't see much chance of freezing (60% protects to -60F). But I guess I agree, better idle than freeze (but there are better ways to prevent freezing - block heater is one). Being able to start it is another issue (not the OP's question though) - I can certainly understand if you did not have block heater provisions in extreme cold weather like Skill_Kills friend.
__________________
Mark
  #10 (permalink)
Old 02-02-2011, 07:36 PM
036.0stroke's Avatar
036.0stroke 036.0stroke is offline
2003 Ford F-350
036.0stroke is starting off with a positive reputation.
i have a high idle module out of an ambulance does that help the extended idle probs?
sorry not meaning to hyjack his thread
  #11 (permalink)
raptor131's Avatar
raptor131 raptor131 is online now
raptor131 has a good reputation on FTE.raptor131 has a good reputation on FTE.raptor131 has a good reputation on FTE.
this would be a great suggestion for Myth Busters. The only way to know would be to place some sort of "flow meter" in the fuel line, or to drain the tank and place only 1 gallon of fuel, and seeing how long it takes to run it out of fuel, but no one who owns a diesel is going to let a 6.0 run out of fuel on purpose so flow meter or nothing, call Myth Busters!
__________________
05' silver f-350 lariat 6.0 psd 4x4 crew cab drw, 4"inch turbo back exhaust, BPD oil cooler condenser mount, powermax turbo,dc power 190Amp OEM High Output Alternator , coolant filter, auto meter: boost, coolant temp, trans temp, egt, voltage. scan gauge II, Rds 91 gallon fuel tank toolbox combo, ready lift 2.5 leveling kit, blue spring mod.Fumuto oil drain, AE w/ford enhanced bundle.Air lift 5000 series rear air bags
  #12 (permalink)
Old 02-02-2011, 07:38 PM
bismic's Avatar
We need to remember that a 6.0L flash has it increasing the idle RPM's periodically, so it will be more fuel consumption than the older diesels.
Also (regarding Ford's position on extended idling):
Page 14 of the 6.0L Diesel Manual:
The following cold weather idling guidelines must be followed:
• Avoid idling the engine for more than 10 minutes at a time.
• Use Motor Craft Cetane Index improvers of a non-alcohol based from a reputable manufacturer.
• Maintain the engine cooling system properly.
• Do not shut the engine down after an extensive idling period (10 minutes or more). Drive the vehicle for several miles with the engine at normal operating temperatures under a moderate load to burn off any accumulated carbon and varnish.
• Consider using an engine block heater.
• For extended idle times use an approved idle speed increase device.
__________________
Mark
  #13 (permalink)
Old 02-02-2011, 07:40 PM
bismic's Avatar
Quote:
In the early days, some folks actually were playing with the fueling tables (programming). Matt (from Spartan) may have been one of them. It is pretty much the same principle as the lie-o-meter. IIRC, they (whoever they are) came up w/ close to the 0.8 gph number. We all know that the lie-o-meter can be off by 10 or 20% (or more) though.
I will try to find the old posts.
__________________
Mark
  #14 (permalink)
Old 02-02-2011, 08:00 PM
bismic's Avatar
Here is one of the old posts I was remembering:
http://www.ford-trucks.com/forums/55...tion-idle.html
and another one from the archives (just can't find the one I was specifically looking for though):
http://www.ford-trucks.com/forums/49...high-idle.html
__________________
Mark
  #15 (permalink)
Old 02-02-2011, 09:17 PM
High Binder's Avatar
High Binder High Binder is offline
High Binder has a good reputation on FTE.High Binder has a good reputation on FTE.High Binder has a good reputation on FTE.
Yes, low idle leaves a lot unburnt fuel traveling though the system (the flame in the combustion chamber takes a drastically different and far smaller shape at idle). So higher idle reforms the flame into a ball shape (which burns far more effectively) and burns off nearly all of the fuel. So low idle is creating a wet system and high-idle + is dry, and you want a dry system. <--- layman terms.
__________________
Masters in Mechanical Engineering/Chem minor. 6.5yrs Caterpillar R&D but currently pursuing law degree (patent law). Member ASME & student member STLE & SME.
2004 F350 6.0. Lariat FX4. Other assorted cars/bikes.
Tags
58, 60, cold, diesel, ford, fuel, gas, idle, idling, liter, long, powerstroke, truck, turn, v10, weather
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
