a real econoline steering fix!
Old 07-04-2015, 09:33 PM
Oz Econoline's Avatar
Oz Econoline
Oz Econoline is offline
Thanks nszceta
Does any one know if this bracket can fit the earlier vans if not does any one know if there is a bracket for these vans (76)
  #377
Old 09-24-2015, 11:06 AM
CheesyRider's Avatar
CheesyRider
CheesyRider is offline
I noticed there's one for sale on Ebay if anyone is interested: http://www.ebay.com/itm/-/291572804572?
  #378
Old 09-24-2015, 03:44 PM
vettex2's Avatar
vettex2
vettex2 is offline
Thanks.
I'm watching it.
  #379
Old 03-28-2016, 10:12 AM
Mitch Eckler's Avatar
Mitch Eckler
Mitch Eckler is offline
Talking Where to buy!
Ford 6.0, 6.0l powerstroke engine, 5r110w transmission - Diesel Redemption has the parts for this. They sell the complete used part. Those guys are great and the stabilizer is only a couple bucks through them.
I wanted to get mine in before the weekend and he rush shipped mine to me for $70... Seriously great dudes over there.
Contact Jeff and he'll hook you up.
His email jeffb60md@aol.com
  #380
Old 05-21-2016, 10:02 AM
rebar13's Avatar
rebar13
rebar13 is offline
My van had a stabilizer installed, but I still had a bit of wander so I had my alignment guy adjust the caster to 5.5 degrees. It steers much better now, but I noticed my stabilizer was leaking oil when I removed it to install a new alternator.
I want to replace the leaking stabilizer, But it looks like I don't have the same mounting system. My stabilizer has threaded rod on both ends.
Does anyone have a guess what I have so I can find a replacement?
Thanks!
  #381
Old 05-21-2016, 10:12 AM
JWA's Avatar
JWA
JWA is online now
Received 1,410 Likes on 1,112 Posts
I'd take that shock into a local parts seller and see if they can match it up with something available.
The double threaded ends are odd for a steering stabilizer, at least the one's we've seen and discussed here.
I wanna think Monroe would be a good place to start looking, perhaps they have fit & match by size etc on their website?
Adding 5+ degrees caster is a known improvement in the E-Series---were special bushings used to achieve that in your E-Series?
  #382
Old 05-21-2016, 10:26 AM
rebar13's Avatar
rebar13
rebar13 is offline
Thanks.. Yes INGALLS 594 bushings.
  #383
Old 05-21-2016, 01:18 PM
vettex2's Avatar
vettex2
vettex2 is offline
If so, I can make one easily.
If not what is the angle ?
I can't see paying 60 bucks for it.
  #384
Old 05-22-2016, 08:49 AM
JWA's Avatar
JWA
JWA is online now
Originally Posted by Oz Econoline
Thanks nszceta
Backing up just a bit post-wise I believe 1978 was the change over year, where the current suspension came into being. Chances are these brackets can be fitted that far back but I don't know for certain, just a WAG here.
Monroe makes a "universal" stabilizer kit which might be adaptable for the earlier years, again just a WAG here.
Rebar13: Thanks----thought those were the parts but wanted to make sure.
  #385
Old 05-22-2016, 07:53 PM
Wildman25's Avatar
Wildman25
Wildman25 is offline
Thanks!
rebar 13,
Came across the one your looking for when I was looking for something else-
Napa has it, Part # NS SC2912, $39.99 /Each
After driving 2 different 90's era cube vans with the Steering Damper OEM, and now driving the 'new-to-me' 2005 cut-away, it really need the damper installed, can tell a big difference, nice part is, I got a '94 E350 for parts
  #386
Old 05-22-2016, 09:30 PM
rebar13's Avatar
rebar13
rebar13 is offline
Originally Posted by Wildman25
rebar 13,
Thanks allot! Monroe SC2912 Magnum Steering Damper
I took my van on the interstate today without the stabilizer. I did notice it steered easy or a light feel but it wasn't wandering at all. I think the stabilizer is a good idea, but the caster was the most noticeable for me.
  #387
Old 07-10-2016, 02:04 AM
FrankGRUN's Avatar
FrankGRUN
FrankGRUN is offline
Just a quick note to report that I purchased and installed a Rancho RS5402 Steering Stabilizer kit on my 1982 E350-based Motorhome with 460/C6 RWD powertrain. I was assured by the vendor (Summit Racing) that it wouldn't fit since the manufacturer only listed the F150, F250 and F350 as appropriate fitable applications. The frame mounted end piece bolted in place with some serious effort. Otherwise, no issues. The vague steering wandering is gone and it handles well - beyond expectations!
  #388
Old 07-10-2016, 06:01 AM
wiskeyVI's Avatar
wiskeyVI
wiskeyVI is offline
What was the issue with getting the frame portion on?
  #389
Old 07-11-2016, 01:00 AM
FrankGRUN's Avatar
FrankGRUN
Just a real fight for the tight space to locate the outer half of the frame mounted bracket. Very tough to get at! After that the install was very easy. Best if you have very small hands!
  #390
Old 07-11-2016, 01:45 AM
Oz Econoline
Hey FrankGrun
Can you give me the Part numbers for the brackets and the damper and where you got all of these parts from Thanks and I will try and get them for my 1976 Econoline
Cheers Darin
Quick Reply: a real econoline steering fix!
