5.8 coolant sensor housing leak-ready to go postal!
ENCHO: THIS IS AN ANCIENT THREAD GUYS, I DECIDED TO BRING IT UP BECAUSE IT HAS RELEVANT INFO, NO NEED TO POST AN ANSWER FOR THE OP
The pix attempt to explain this. The sensor housing pipe, or whatever it is called has a hole where the rubber hose goes in. No, I can not slide the hose up to cover it. My mechanic who I trust pretty good says the housing was NOT designed to come off. So, can I get it off? Can I bypass this by just connecting the two hoses (he said I will ruin my engine because the computer will not get the temp info). How do I replace that? Neither Ford or any other parts store caries that fitting. I am ready to snap, I have to plow and I am loosing money. Thanks!
http://www.flickr.com/photos/wigman65/5407534949/
By bypassing it I don't think it'll ruin the engine. Worst case scenario it'll make you throw a check engine light. AFAIK, that fitting is removable, but its a bear. I think they put thread locker on it from the factory so that makes things tougher. But, yes, it is removable, just be careful not to snap anything. Lots of PB blaster, some heat (if you can get that close) and patience.
I hear you about the plowing...my plow truck is down now (I'm also in CT) and my back is hurtin-BAD!
Roger
Roger
5.8 ecs to intake manifold anti freeze leaking out
You cannot bypass this. They do not make the part anymore you can check with ford parts for the E6TZ18599A ELBOW parts secondary sellers. This part screws into the intake manifold and has two ports on the bottom one is a 1/4 inch nipple for cooling off the throttle body the other is a female threaded or a rigid pipe that goes to one side of the heater core there is a third above these two a threaded 3/4 or 5/8 for the insert of sensor itself. This part is made of stainless steel oem. You can use brass fittings from a pluming supply or stainless and use reducers or stub outs. Cut the rigid line and attach a hose with clamps this should get you a few years. There are dealers that still have this part in stock like Hawaii but at a cost of over 100 dollars for a 5 or 10 dollar fix you do the math. Another option is to take the item completely off. Sand blast the unit to remove any rust and re weld the leaking section.
g-unit, thanks. I did a temp fix with hose and a hose clamp. When the wx gets better I am going to cut of the two tubes, take the sensor out and screw it out. I will rebuild it or make a new one. I have a friend who is a machinist and when I showed it to him he laughed and said he cold make one from scratch easy.
I see a business opportunity here. I could not find ANYONE who carried it. I may pull one off a block a the junk yard for my initial prototype. With millions of 5.8Ls out there I can't be the only one who ever had this problem.
One question: in your opinion, how hard will it be to un-screw that. Dissimilar metals and 14 years of not coming off...I am guessing heat it up and pent oil for a while.
Thanks
Thanks
Thanks, good info...my trusty mechanic also yelled at me because the coolant hasn't been flushed since Clinton was in office handing out cigars....corroded coolant can also cause metal fatigue too. In this case a pin hole which quickly escalated to a larger hole. Second time it has happened. Must flush the system soon...
Thanks
Thanks
I had the same thing happen on mine and couldn't find one in a salvage yard or anywhere. I built a replacement from fittings off the shelf at Lowes. I replaced it recently with one I got from a parts truck I lucked into, but if you're interested I'll see if I can find it in the garage and see about pics or a diagram.
