Need help finding heater control valve
I have a 73 P400 and need to find a heater core control valve. So far not finding any exact replacements. Given its age and being a P400, wondering if I just need to find something that works, thats not original/custom.
Not sure how to know if something will work or not. I'm guessing they are fairly standard functionally? Do I just look for any that are cable actuated and have 4 ports? Below is a photo of what I have.
Here are a couple valves I found online that I'm wondering if one of them might work?
- https://www.ebay.com/itm/Bypass-Heat...-/112454920191
- https://www.amazon.com/Four-Seasons-74643-Heater-Valve/dp/B000C2UVK0
Your best contact on this forum is probably Number Dummy (Bill). He's good with Ford parts, part numbers, and sources. That valve is completely different from my F series. Either of those you found "might" work, but it's difficult to tell without more information. If you could have them in your hands and compare to yours it would be a lot better. As a minimum, be sure that the on/off function works as does yours. (cable pull = on; or cable push = on). I tried the Four Seasons catalog, but it only showed a P-100 and a P-350, and I didn't know what engine you had. 4 Seasons | English Best wishes.
I might PM Number Dummy. I'm not sure its a Ford part though as the heater core and rest of heater setup are part of the custom van body. I couldn't find it in the MPC.
I might just need to purchase the cheaper ebay one and compare it to mine as you suggested and see if it operates the same way. I believe this type of valve recirculates coolant back to engine when it is "off", rather than simply blocking flow and letting coolant circulate/bypass in the block.
Anoall747
02-24-2019 01:55 PM
1977cj5
09-26-2018 12:28 AM
centralNH
03-23-2014 05:12 AM
