Help Trailer brake troubleshooting
My trailer brakes didnt work today when I hooked up to the trailer. I pull this trailer almost everyday and they have been working fine until today. I have checked the fuse. The blinkers work fine on the trailer. I opened the 7 way connector and the wire is still connected. Cleaned the terminals. Disconnected and reconnected the brake controller and still nothing. I dont know where to go from here, what to test how to test it?
I just used a piece of wire & jumped from the brake pin to ground on the truck plug. the light lit on the controller telling me the brakes on the trailer end was open (not grounded). I found the wire broken where it attached to the frame of the trailer in the area of the axles.
Thanks for the help. Although I wasnt able to figure it out doing it that way. I was able to use the idea at the brake controller to eliminate it as the problem. Then I went back to the truck side trailer connection. I disconected it on the back side and cleaned one of the terminals and sprayed wd 40 in there. Plugged it back in and it worked! "Reps" coming
Chalkie
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-26-2012 09:19 PM
jjlrrw
12-19-2011 08:54 AM
