the cure vs upgrade torque converter
How many Miles are on the truck you are considering? How much weight are you going to be hauling/towing? The E40D trans is unfortunately the major 'weak link' per say in the PSD drive train. If it was well taken care of, then you shouldn't have many issues. Typical upgrades to help longevity are a good trans cooler and a shift kit or valve body swap. The trans cooler keeps your temps down and the shift kit will help the shifts happen faster with less slipping between gears.
Those will only help if the trans has been maintained properly, if not you may be looking at a rebuild.
The cure product will help with your 3rd-->OD up and down shift as I mentioned above, making the T/C lock and unlock faster. If you find your RPM's flaring between that gear shift, you may want to consider the product. User MADVAN (Bill) on this form sells them and can be reached at shiftsolutions at yahoo dot com
there is supposed to be 40k on the trans 175k on truck. I pull 10k trailer occasionally but coyote hunt a lot where I am driving through deep snow and beat on the truck some. I have had a e4od in a 91 with 5.8 that held up ok but obviously didnt have near the torque. I am just looking to possibly prevent a few problems before they arise. is there any advantage to putting a different tc in it or should i just add a shift kit, cooler, and the cure? Also if I do a shift kit will it be effected if I chip the truck (nothing wild) as some chips/programmers change shift frimness. Should the programmer then be done first to see how it shifts before modding the valve body. Thanks a bunch guys- dont know much about transmissions
I'll PM you one with better resolution if you want, I downsized it so I wouldn't eat up a lot of thread space
EDIT: Sent you a PM
Or just look here http://inlinethumb60.webshots.com/44...600x600Q85.jpg
EDIT: Sent you a PM
