Intake Manifold and 4 Barrel Suggestions Needed for a 352
Old 01-24-2011, 04:57 PM
BigMikeUGA's Avatar
BigMikeUGA
BigMikeUGA is offline
My '65 F250 has a 352 / 2bbl. I need to replace the intake manifold gaskets and figured since I was going to put a 4bbl on it, I might was well do it now.
I was thinking of an Edelbrock Performer intake manifold and a Holley 600 CFM 4bbl with an electric choke.
Thoughts, experience, suggestions?
Also, suggestions on how to jet it for a stock 352 are welcomed.
Old 01-24-2011, 05:11 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Ziegelsteinfaust is offline
Thats pretty much going to be your winning combo.
You could try an edelbrock 500, but it won't be to much different. Some people prefer the smallest carb possable. Me I like 1 size bigger to aid in hwy cruising.
If you wanna try an Edelbrock I would use the thunder AVS type. Its a big improvement for the average guy to tune.
I perfer to buy a used carb, have it rebuilt, and tuned by prefessionals like these guy.
Performance Carburetors - Custom Holley Carb Specialists
It usually works out to be a bit cheaper, and the reliability is up from a tuning stand point.
Old 01-24-2011, 05:23 PM
BigMikeUGA's Avatar
BigMikeUGA
Old 01-24-2011, 06:26 PM
dsrtjeeper's Avatar
dsrtjeeper
dsrtjeeper is offline
Slick 60's :: View topic - Edelbrock carb install on 352???
The Edelbrocks are very street friendly and easy to tune. I threw a 600CFM Edelbrock Performer carb on my 352. You can get decent performance from a factory Ford 4v intake with tall ports. The stock intakes are heavy and you could save weight by going aftermarket if that is important to you. There seems to be some debate on whether the Edelbrock FE intake is worth the money. Talk to these guys is you want more performance: 332-428 Ford FE Engine Forum
Good luck!
Old 01-24-2011, 08:24 PM
Ziegelsteinfaust
Those are good choices.
Like said above there is some debate wether the Edelbrock manifold is better, but it is easier to install since it is alot lighter.
Old 01-24-2011, 08:47 PM
nvrgrwup's Avatar
nvrgrwup
nvrgrwup is offline
Hey guys this is a subject near and dear to my heart. I'm on the way to putting a"58" 352 PI in my "64" and I'm tempted to use the stock autolite. I think I'll use the aluminum intake for all the reasons stated as well as some added performance. Got to be better than the technology of "58" don't you think? Let me know your thoughts. Russ
Old 01-25-2011, 01:35 AM
Boss9F100's Avatar
Boss9F100
Boss9F100 is online now
For a lower perf 352 the Performer intake is a great choice! I put a 550 CFM Holley and mine and it runs AWESOME! Gained a noticeable amt of power and think the mileage is better too although bad weather came and I parked it for winter.. I took off the Edelbrock name and painted it engine color so looks like it belongs there. The 550CFM Holley was new so it performs flawlessly too.
Old 01-25-2011, 07:12 AM
BigMikeUGA's Avatar
BigMikeUGA
I'm so freaking jealous of how good that engine bay looks. Mine will get there but it will be a while.
I think I want to go with aluminum because I've heard the stock cast iron intakes are heavy and difficult to install. Afterall, I'm pulling the intake to get rid of a leak as it is.
But, if I find a factory 4bbl intake, what should I expect to pay for it?
Holley has refurbished 600cfm carbs for $199. They say on their web site that they are returns that are due mainly to customers returning them for lack of know how to properly adjust them. The go through the entire carb. Since they aren't really "used" and just returns, I feel the $100 savings would be worth it.
Old 01-25-2011, 07:52 AM
CropDusterMan's Avatar
CropDusterMan
CropDusterMan is offline
I may be going the Edelbrock intak/carb route? One question I had-the High Perf. machine shop that redid my stock heads
(amazing shop) told me that the new aluminum heads should be faced by a shop prior to install as they are rarely true?
What do you guys think on that? Do they ever check intakes for the same?
Old 01-25-2011, 08:59 AM
baracade's Avatar
baracade
baracade is offline
I am in Texas and I have a ford 4V intake for the 352, will sell cheap but the shipping cost could be prohibited depending on where you live.
Old 01-25-2011, 09:12 AM
BigMikeUGA's Avatar
BigMikeUGA
I figured shipping would be pretty expensive. I might try to find one locally but I like the idea of the aluminum intake. My '65 is a RestoMod so I'm not concerned that the intake is factory. I just want one that will perform well and won't leak.
BTW - PM me your price and I'm in 30075.
Old 01-25-2011, 09:23 AM
jd_sylvia's Avatar
jd_sylvia
jd_sylvia is offline
I am getting ready to go to aluminum myself and already have a cast 4v with a Holley 600 manual choke. It runs great but I picked up the aluminum for a great price at a local auto swap meet. I also picked up a new Holley from Jegs on sale just need to finsh the heads.
I am in CA and will have a cast 4 barrel just hanging around.
Old 01-25-2011, 10:12 AM
likeagoodbook's Avatar
likeagoodbook
likeagoodbook is offline
The Holley 4160 has worked great for me, very affordable, lots of information out there, relatively easy to rebuild (if you know what your doing) and easy to adjust and tune. Mine has run like champ ever since I did a rebuild and the electric choke seems to work well in the cold weather.
Old 01-25-2011, 11:00 AM
thechief66's Avatar
thechief66
thechief66 is offline
I had a stock 4bbl intake (if memory serves it was the C6AE) on my old 66 & I replaced it with a Performer intake. It made a noticable improvement in "seat of the pants" performance.
I also would recommend the Edelbrock carbs for reliability & easy tunability. Plus, they look sharp!
Old 01-25-2011, 06:58 PM
dsrtjeeper's Avatar
dsrtjeeper
I paid $50.00 for my factory 4v intake. I'm not a Holley hater by any means, but the Edelbrock carb is definately the most user friendly carb I have ever installed. I literally bolted it on and fired her up. It was that easy. Threw it on the emissions sniffer and it's right in range. Holleys are better when it comes to big cams.
Quick Reply: Intake Manifold and 4 Barrel Suggestions Needed for a 352
