Sacramento Vintage Ford 3" Drop Axle
Old 01-18-2011, 10:26 AM
yelosub79's Avatar
yelosub79
yelosub79 is offline
Im thinking of getting it for my 51 F1.
Anybody using this axle or know anything about it?
Likes? Dislikes? Quality? Is it worth $400?
Ive also looked at Nostalgia Sids drop axle but think I like this one better.
Opinions on both?
Other axles available?
<CENTER></CENTER><CENTER></CENTER><CENTER>
07129
TUBE AXLE 1948-52 3 INCH DROP
Made From 2 inch Steel Seamless Tubing, CNC Machined Ends, Laser Cut And CNC Bent Spring Pads, Lowers The Truck 3 in While Retaining Full Stock Suspension Travel. Also needs 7160-10 Tie Rod Drop Kit, Kit Will Also Work On 1957-60 But Will Only Give A 2 in Drop On Them, Page 19, 2009PT</CENTER>
Old 01-18-2011, 11:56 AM
jaye's Avatar
jaye
jaye is offline
I think I was one of the unlucky ones with this axle. I purchase one in 2007 and the camber was off by more than 3 degree both sides. I called the guy who made the axle and he said to get it fixed which he paid for; the axle bent in the middle and the spring pad welds broke; other than that it sat really well and drove OK. I sent it back to the vendor and brought an original axle that was stretched which is what I have now.
Old 01-18-2011, 12:18 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,450 Likes on 1,397 Posts
I'm no engineer, but it always seemed to me that whenever you weld three pieces of dis-similar metals together and try to use it to hold up 3000 pounds, with the stress placed right over the weld joint, well.... it just doesn't seem right, to me. They may be perfectly fine, but my brain tells me that what happened to Jaye wouldn't be a fluke. It wouldn't be my choice.
My 2c, fwiw.
Old 01-18-2011, 02:23 PM
yelosub79's Avatar
yelosub79
Huh, thats not real encouraging to hear. Thanks for the info though.
My 2c, fwiw.
I was thinking about that also. Hopefully the axle ends slip inside the crosstube for added strength and are then welded....
Maybe I will have take another look at the Nostalgia Sids extended axle...
Old 01-18-2011, 03:47 PM
jaye's Avatar
jaye
jaye is offline
From an ispection of the one I had it appears that the square solid piece was butt welded to the round tube, then the plates welded over both pieces.
Old 01-19-2011, 10:10 AM
yelosub79's Avatar
yelosub79
sucks......
What kind of stretched axle do you have now? do you like it?
Old 01-19-2011, 11:57 AM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
Originally Posted by yelosub79
sucks......
That was going to be my question. Where did you find it, or do you know someone that can modify one for about a 2" drop?
Old 01-19-2011, 12:08 PM
yelosub79's Avatar
yelosub79
Nostaligia Sids sells a 2" and 3" stretched axle for $300 ($350 w/out core). They are the only other company I know that sells them....thats why I wanted to know which axle jaye has.
Old 01-21-2011, 05:20 PM
abrwndude's Avatar
abrwndude
abrwndude is offline
I have one from Sid. Love it. Sid is a great guy and will help you out all the way to installation. Give him a call.
Old 01-21-2011, 07:05 PM
yelosub79's Avatar
yelosub79
Glad to hear it!! Thats reassuring since I just bought one from him today. I hate forking out that much money without physically seeing it first. Cant wait to get it and put it in though.
Old 01-22-2011, 10:24 AM
jaye's Avatar
jaye
jaye is offline
I got mine from Dave Mann at Roasters.com once I talked to him and sent the money I got pretty quick I love it no problems and it's been on for over two years now. I paid $350 outright & shipping
Old 01-22-2011, 11:30 AM
abrwndude's Avatar
abrwndude
here is the new one from sid and my old one. Top is the drop axle. Comes in painted and looks good. cant really tell where it was stretched!
Old 01-22-2011, 08:39 PM
yelosub79's Avatar
yelosub79
looks good! Thanks for the pic.
Mitch1129
33
07-02-2015 09:50 AM
BlueOvalBud
Offroad & 4x4
01-22-2013 07:28 AM
echobunny
19
07-12-2010 12:16 PM
thesprocket26
Offroad & 4x4
08-24-2004 08:53 PM
Quick Reply: Sacramento Vintage Ford 3" Drop Axle
