Anyone using a different heater??
Old 01-17-2011, 05:37 PM
tjdad62's Avatar
tjdad62
tjdad62 is offline
I tore my heater apart this weekend and found one of the panels that sits behind the heater core to be very rusted out. Has anyone found a good aftermarket source for replacement pieces?
On another note, how many of you have gone a different route and used a setup from another vehicle? If so, make and model?
Old 01-17-2011, 07:06 PM
firstrider's Avatar
firstrider
firstrider is offline
Please post a pic of the rusted out piece . May be able to help you out .
Old 01-17-2011, 08:08 PM
fifty-two_f1's Avatar
fifty-two_f1
fifty-two_f1 is offline
yes pictures please!! I have parts for the original type heater if that is what you have.
Old 01-17-2011, 10:17 PM
orcas tow's Avatar
orcas tow
orcas tow is offline
Old 01-17-2011, 11:16 PM
tjdad62's Avatar
tjdad62
tjdad62 is offline
I posted pics in my album called "Heater Part"
Old 01-18-2011, 03:01 PM
fifty-two_f1
I could not find them.
Old 01-18-2011, 04:01 PM
9teen56f100's Avatar
9teen56f100
9teen56f100 is offline
Old 01-18-2011, 04:07 PM
tjdad62's Avatar
tjdad62
tjdad62 is offline
Originally Posted by 9teen56f100
Yep, thats one side. From what I took apart, there were 4 rubber (used to be anyway) insulators that I think insulated the core from the housing. Maybe it was to keep the outer case from getting too hot to the touch. Like I said, it doesn't bolt to anything, it just rests in there and I was thinking of just leaving it out.
Old 01-18-2011, 04:42 PM
Björn's Avatar
Björn
Björn is offline
this is not type you have
Old 01-19-2011, 10:20 AM
firstrider's Avatar
firstrider
Have 8 of them media blasted , epoxy primed and ready for instal on all the Magic Air heaters under restoration . Sure wish I had an extra to help you out .
Maybe time to hone your restoration skills . Media blast it and see what you have .If any rusted out /holes appear these can be repaired by using some 3/4 oz. fiberglass mat with resin . Apply directly to the clean metal . May have to make little dammed up areas to hold resin while it cures .See thread titled = '48 -'50 blower motor case= to see what can be repaired .Good luck . Denny
Old 01-19-2011, 12:33 PM
Fordman49F1's Avatar
Fordman49F1
Fordman49F1 is offline
My truck came with no heater, and I couldn't find one I could afford. Instead, I have an earlier chrome Firestone heater. No defrost, but 5 vertical doors, and no leaky core. Scored it for next to nothing from a good friend. I have no idea when it was from or what it went to.
Old 01-19-2011, 07:52 PM
purple51's Avatar
purple51
purple51 is offline
Thumbs up heaters
I'm using early datsun mini truck heater......It's a small compact unit easy to hang and mostly plastic....My truck 1951 f-1 And I'm The"EARL" like in Duke Of the Darkside
Old 01-20-2011, 05:04 AM
big job's Avatar
big job
big job is offline
I have been using 1973-1979 pickup the hole assembly in all my trucks so
the trucks have wicked defrosters.
Old 01-20-2011, 06:01 PM
tjdad62's Avatar
tjdad62
tjdad62 is offline
I media blasted the pieces yesterday and have the parts that need repairing in fiberglass right now. Will be using the Krylon silver/gray hammertone finish on the outer pieces and flat black on defroster vents and the under fender air tube pieces.
Old 01-21-2011, 08:27 AM
Fordman49F1
I am just gonna throw this out there....if anyone has an extra heater laying around...perhaps one they would not mind parting ways with...I would like a stock heater box so I could actually have defrost. Condition of the fan motor does not matter cause I will be installing a 12V fan.
Quick Reply: Anyone using a different heater??
