Transmission will not go into drive.
Old 01-17-2011, 08:39 AM
terrydean's Avatar
terrydean
terrydean is offline
I was driving my 1998 Ford F150 the other day and pulled into a driveway. At that time, the transmission quit pulling like I put it in neutral. It shifts from park and goes into reverse but not drive. It has the 4.6L and is 2 wheel drive. Thanks.
Old 01-17-2011, 11:31 AM
jgeese's Avatar
jgeese
jgeese is offline
Start with the obvious and check trans fluid level first. Next, do you have a check light on or overdrive light flashing? More info is better...
Old 01-17-2011, 09:13 PM
Ultramagdan's Avatar
Ultramagdan
Ultramagdan is offline
Welcome to the site!
The cable to the tranny may have been compromised. If you can place it in D, and nothing happens, I would start with the above post and then with someone in the truck FIRMLY holding the brake down, slide underneath it and manually move the shifter dog on the tranny (it's on the driver side). Do this with the engine OFF. If the gear selector on the column does not move, the cable is bad.
I would also see what the tranny fluid smells like. If it smells burnt, its cooked.
Old 01-18-2011, 08:30 AM
terrydean's Avatar
terrydean
Transmission
Thank you for your comments on this. I have checked the cable and it is fine. Also the fluid is like new ( no burn smell or discoloring). I think it is a solenoid but I need a diagram of the transmission to confirm. I also found out it may be the safety neutral switch that will may not let it go into drive.
Old 10-01-2013, 09:08 AM
Erin Smith's Avatar
Erin Smith
Erin Smith is offline
After it would not go in to drive, i backed it up and turned off engine, and truck would not start.
Cjstates
1983 - 2012 Ranger & B-Series
05-15-2015 01:46 PM
kemperhills
1997 - 2003 F150
03-01-2015 08:02 AM
Big Big Blue
12-07-2014 10:22 AM
DmanNC
01-14-2014 06:20 PM
greenstar
26
12-15-2013 01:15 PM
Quick Reply: Transmission will not go into drive.
