What is a Remote Start Activation (-) input
Old 01-16-2011, 07:30 PM
Woody2010's Avatar
Woody2010
Woody2010 is offline
I am trying to get my Omega remote start working and tech support sent me an email telling me I needed to hookup the White/Blue Wire -Remote Start Activation (-) input. The book says:
White/Blue Wire - Remote Start Activation (-) Input
This input will activate the system’s remote start function when it receives a negative
pulse. Another pulse during remote start operation will turn off the remote start.
CONNECTION:
Connect this wire to any device that you desire to activate the
remote start feature. It requires a negative pulse input.
I don't have a clue what this is.
Any ideas?
Thanks
Old 01-19-2011, 06:12 PM
ReAX's Avatar
ReAX
ReAX is offline
That sounds like you don't have a RS button on the fob. I remember directed had a system you could add on and use the OE fob. Basically you hooked it into the door locks so when you double tapped the lock, it would start the engine.
Do you have a fob with button for remote start?
Old 01-19-2011, 06:54 PM
Woody2010's Avatar
Woody2010
Correct, I am using the OE remote. It does not have a Start button. My RS is set up to use Lock-Unlock-Lock
Old 01-20-2011, 07:29 AM
ReAX's Avatar
ReAX
ReAX is offline
If you don't have one of these already, this will help
F-150 LIGHT DUTY 2009 -2010
KEY T-HARNESS IMMOBILIZER
N/A N/A FORD's Transponder Anti-theft, requires Bypass Module, See Note #1
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED (+) (Fusible Link A AND B) @ SJB, BLACK 1-PIN PLUG(G) PIN1, Note #2
STARTER BLUE/WHITE (+) @ IGNITION SWITCH, (GRAY 10-Pin Plug), Pin 10
STARTER 2 N/A
IGNITION 1 WHITE/ORANGE (+) @ IGNITION SWITCH, (GRAY 10-Pin Plug), Pin 1
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 PURPLE/GREEN (+) @ IGNITION SWITCH, (GRAY 10-Pin Plug), Pin 5
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE BLUE/GRAY (+) @ IGNITION SWITCH, (GRAY 10-Pin Plug), Pin 3
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) PURPLE/WHITE (+) in DRIVERS KICK PANEL or SJB (GRAY 13-PIN PLUG(E), PIN 6, Note #2
POWER LOCK GRAY/YELLOW (-) TYPE (B) in DRIVERS KICK PANEL or SJB (GRAY 26-PIN PLUG(C), PIN 17, Note #2
POWER UNLOCK PURPLE/GRAY (-) TYPE (B) in DRIVERS KICK PANEL or SJB (GRAY 26-PIN PLUG(C), PIN 4, Note #2
LOCK MOTOR WIRE GRAY/BROWN (+) (5-wire type) in DRIVERS KICK PANEL or SJB (BLACK 32-PIN PLUG(D), PIN 6, Note #2
DOOR TRIGGER GREEN/PURPLE (-) IN DRIVERS KICK PANEL
DOMELIGHT SUPERVISION GRAY/PURPLE (+) in PASSENGER KICK PANEL or SJB (GRAY 14-PIN PLUG(A), PIN 9, Note #2
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN BLUE/WHITE (-) @ HORN SWITCH or SJB (BLACK 52-PIN PLUG(B), PIN 41, Note #2
TACH Any wire NOT BLUE (AC) @ ANY FUEL-INJECTOR
WAIT TO START LIGHT N/A
BRAKE PURPLE/WHITE (+) @ BRAKE SWITCH or SJB (BLACK 52-PIN PLUG(B), PIN 40, Note #2
FACTORY ALARM DISARM N/A
ANTI-THEFT FORD's Transponder Anti-theft, requires Bypass Module, See Note #1 AT IGNITION TUMBLER
NOTES
Note #1: Transponder System, Requires interface Module, Part # XK04 with PKF3 1.03 firmware, XK05 with 5.PKTI 1.02 firmware ( no key needed to leave in module) or 791bypass module and spare ignition key....to purchase interface module, Google part number and click shopping.
Note #2: the SJB (Smart Junction box) is located in the Passenger Kick Panel.
The power lock wire already pulses ground, so you should be able to tie right into it. Ford does use a sleep mode on some vehicles so a diode may be necessary.
Bryan Hagan
12-19-2015 07:50 PM
Mr.ford
1997 - 2003 F150
09-09-2012 05:59 PM
resq302
03-04-2012 07:32 PM
Woody2010
2009 - 2014 F150
54
03-19-2011 05:47 PM
Nickiboy
Electrical Systems/Wiring
02-27-2006 05:48 PM
Quick Reply: What is a Remote Start Activation (-) input
