Gauges.. And need help
Old 01-15-2011, 05:41 PM
Jessef250's Avatar
Jessef250
Jessef250 is offline
I just got my glow shift gauges at my house! I'm excited lol I know how to hook up the pyro, and the boost.. I am lost on how to hook up the engine oil temp. Anybody know? Thanks in advance
-jesse
Old 01-15-2011, 05:49 PM
Waltdog's Avatar
Waltdog
Waltdog is offline
of American machinists
There is a 1/8 NPT plug right above the filter to tap into oil temp.
Does that help?
What does the sender look like?
Old 01-15-2011, 06:20 PM
Jessef250's Avatar
Jessef250
Yessir that helps alot!!
And what do you mean by the sender?
Old 01-15-2011, 06:24 PM
Waltdog's Avatar
Waltdog
Waltdog is offline
"sender" refers to the portion that screws into the testing port.
Also, be sure your ready to screw the sender in once you pull the plug
Old 01-15-2011, 06:28 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
diesel-fitter-bum01 is offline
Or install it when you change your oil next. Can still plumb it donw there though. I like mine,installed them last summer.
Old 01-15-2011, 06:37 PM
bcaughhorn's Avatar
bcaughhorn
bcaughhorn is offline
mine have been good. installed them couple months ago. just done the pyro today while my daughter was locking my keys in my truck
Old 01-15-2011, 06:50 PM
Jessef250's Avatar
Jessef250
Alright I understand now... I am changing my oil this week. Wat do you kno, perfect timing!
Old 01-15-2011, 07:49 PM
tdpower's Avatar
tdpower
tdpower is offline
You could use your oil temp gauge for trans temp as well. You would just have to pick up the right switch and a sending unit for the trans temp. Then you could monitor either one with the same gauge. I think some of the auto parts stores sell the 1/8npt sending units.
Old 01-15-2011, 07:55 PM
big poppa's Avatar
big poppa
big poppa is offline
Congrats on the gauges Jesse, very important to monitor the vitals. As per your signature, "Drive like I stole her" I would consider a trans temp gauge and sender too like Grant and the guys mentioned, our trannies can heat up pretty quick depending on load and ambiant temps..
tritonman2001's Avatar
tritonman2001
tritonman2001 is offline
How do you hook that up and what all would be needed. Not trying to hijack just wondering. I already have the trans temp, and would like to hook it up for the oil temp as well.
Old 01-15-2011, 08:25 PM
bcaughhorn's Avatar
bcaughhorn
i like that idea.. what kind of switch would that need? can i get a sender at my local advance?
Old 01-15-2011, 10:01 PM
tdpower's Avatar
tdpower
tdpower is offline
I think it would be a three way toggle switch but not for sure. Just take your meter to radio shack. In one direction you would have continuity from the wire to the gauge to the trans. temp wire. The other direction would have continuity from the wire to the gauge to the oil temp. So basically you are just running the three wires to the switch and hooking them up accordingly.
I'm sure a local parts store can get a temp sender if not in stock. I'm not sure what the oil temp sender size is but the transmission one should be something like this one (1/8 npt): Auto Meter 2258 Sending Unit Temp - eBay (item 300512691768 end time Feb-06-11 14:55:39 PST)
Old 01-15-2011, 11:15 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
You will need a SPDT (single pole double throw) switch for this. It can be a toggle or rotary switch, doesn't matter. You hook up one sender to A and another sender to B. Then you hook the COM wire to the gauge. This way when you switch it will break the signal and then make the signal to the other sender. Works pretty slick as long as the senders are the same temp rating as the gauge (100-250 or what ever set-up you are using)
Here is the switch I used on my trans temp senders to measure trans temp, and post cooler temp.
Old 01-16-2011, 12:04 AM
tdpower's Avatar
tdpower
tdpower is offline
Ken thanks for the good info...Tried to rep you but I'm in jail.
Old 01-16-2011, 09:47 AM
woodnthings
I decided to do a diagram showing how simple it really is to do this, so take a look below. I put a standard SPDT switch from Radio Shack on the diagram too. Should be something easily found. Carling also makes a SPDT rocker switch for those of you that use them, or are planning on installing an F-650 dash.
You are not limited to a two sender set-up. You can get other switches with multiple contacts. I mentioned a rotary switch previously, they work well when running more than three senders to one gauge. I decided to just use the SPDT toggle as it fit better in my pod location.
Quick Reply: Gauges.. And need help
