1989 ford f150 302 to 351 swap
Old 05-10-2014, 08:46 PM
JRS2's Avatar
JRS2
JRS2 is offline
Tman, if you had distributor off and have somebody crank engine with your thumb over spark plug opening, you can see where the pointer is when compression is evident .....
Old 05-10-2014, 09:01 PM
Conanski's Avatar
Conanski
Conanski is offline
Originally Posted by Tman589
To set the timing I put it 10 degrees BTDC on compression stroke and the rotor is pointing to number 1 on the cap which is pointing towards the rear of the engine correct?
Yes that sound right, can you verify your wiring against this diagram..
Old 05-10-2014, 09:41 PM
Tman589's Avatar
Tman589
Tman589 is offline
Ok got it to run (out of gas).But the only way it will start is the distributor turned all the clockwise,and the throttle wide open.But won't stay running on its own.
Old 05-11-2014, 07:32 AM
Conanski's Avatar
Conanski
Conanski is offline
Ok got it to run (out of gas).But the only way it will start is the distributor turned all the clockwise and the throttle wide open
Your distributor is off 1 tooth, pull and restab it 1 tooth CCW. Was that with the 5.0 computer?
Old 05-11-2014, 08:58 AM
Tman589's Avatar
Tman589
Tman589 is offline
Yes with the 5.0 computer
Old 05-12-2014, 11:14 AM
Tman589's Avatar
Tman589
Tman589 is offline
Nothing's working guys..Im about ready to give up and put a carb back on it.
frankosd
Engine Swaps
11-14-2016 10:09 AM
jlmills15
1978 - 1996 Big Bronco
10-20-2016 06:13 PM
C.B.Fiddler81
06-23-2016 09:48 PM
dozernsasha
19
02-12-2016 10:36 PM
blake70
03-23-2012 11:17 PM
Quick Reply: 1989 ford f150 302 to 351 swap
