Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-10-2011, 11:38 PM
kip42 kip42 is offline
Garage is empty, add now
kip42 is starting off with a positive reputation.
Lincoln Navigator and Navigator L fuel mileage and offroad ability?
What kind of fuel mileage would I get with a Navigator/ Navigaotr L 08+ going 70 mph? How do these do off road? Is it possible to get a locker in one? My concern is how low they sit to the ground.
  #2 (permalink)
Old 01-11-2011, 06:12 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Off road?!
Muddy dirt roads maybe, but these ain't going cross-country without specialty wheels, tires, and body frame protection.
Fuel depends on your axle ratios. My 3.73 will push 20 mpg at 70+ on flat roads. But 18 is more likely.
-- Chuck
  #3 (permalink)
Old 01-11-2011, 08:24 PM
Kelly Aitken Kelly Aitken is offline
Kelly Aitken is starting off with a positive reputation.
My 08 L gets almost 20 hiway. I bought mine in Maryland so the 4x4 was used for snow driving I assume. The only time I use it is when I'm backing my trailer up over the curb. The back tires just spin trying to pull the front tires over the curb while trying to push the trailer. It works good though. Have never had a need for it otherwise and certainly wouldn't consider taking this vehicle off road.
Kelly
  #4 (permalink)
Old 01-11-2011, 08:35 PM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
Well, gas mileage is great compared to my '97 F250. The 5.4 in the Navigator does much better than the 7.5 in the truck! Probably 90% of the vehicles you can buy will get better mileage, so if that's your sole criteria you'd do well to look elsewhere.
I've found my Navi L can do lots of things that those other 90% can't do, so I feed it plenty of the cheap stuff and move on.
As far as off-roading, I suppose it depends on what you want to do. These are big buses, especially the L's, so navigating (ha-ha) narrow trails like a CJ or Wrangler ain't going to happen.
The Navi's don't have low range either. But first gear in the 6-speed is plenty deep, so I don't think it's an issue. Also, it's not like you'll be slipping the clutch to get it going.
The traction control is brilliant as well, so I think you'll be able to go places you fit, even without a locker.
Ground clearance... if you have the power running boards it might be a hair better between the wheels than an Expy that doesn't (Expys could have power boards, but try to find one.)
So, hard-core rock climbing? I don't think so. Getting to the cabin, or scouting through some fields? Don't see why not. But put those chrome 20's away and find something more trail approriate. Though far from identical, here's alot of F150 underneath these.
__________________
1997 F250HD 4wd, 460-5-speed Ext. Cab, Blue
2007 Navigator L Dark Blue Pearl
2003 Mercury Marauder, Dark Blue Pearl, Trilogy Supercharged, 13.1 @ 105
  #5 (permalink)
Old 01-13-2011, 02:46 PM
highridercf highridercf is offline
highridercf is starting off with a positive reputation.
i do some ditch diving and ripping down by the rivers which are not at all maintained for work a few times a week and im in canada so... and i drive an 07 el limited. I also live out in the country so at times the "roads" get pretty bad (mud, snow ect).
its no hard core wheeler but it gets the job done. have not got stuck yet (knock on wood)
Tags
07, 1996, 2007, 2010, chip, expect, fuel, gas, get, kind, lincoln, mileage, navigator, real, road, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
