6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
High Current Fuses Location on 09 F250 PSD 6.4
Old 01-08-2011, 09:22 AM
Blind1's Avatar
Blind1
Blind1 is offline
Owner's manual says the high current fuses are located in the engine department. Well, if they are, they hide them prettied damn good. Apparently they are located under one of the batteries, but which one? Your help is surely appreciated. I need to replace a trailer marker fuse.
Old 01-08-2011, 09:36 AM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
should be behind the degas bottle. Power distribution box.
Old 01-08-2011, 10:15 AM
Blind1's Avatar
Blind1
Blind1 is offline
Thanks Senix, that is where it's located. BTW - folks if you have to change a fuse in this box the part/object on top of the fuse box, is released via thumb screw, which either you to need to have small hands, or pliers. The clip of the fuse box is on front toward head light. Pull up and push it back.fficeffice" /><O></O>
Old 01-08-2011, 01:18 PM
Larry NCKS's Avatar
Larry NCKS
Larry NCKS is offline
I don't have small hands and have not had a problem with this.
Old 10-02-2013, 11:31 AM
mbrandeskc's Avatar
mbrandeskc
mbrandeskc is offline
Thanks for this thread. I too had no brake lights or turn signals on my 2010 F-250. Checked the fuse box in passenger compartment. Didn't realize there was also one under the hood. Owners manual doesn't have that one documented. :-) The fuse for the trailer is a 25amp mini. Just FYI.
Here is a picture of the fuse box under the other thing with the thumb screw on it.
Originally Posted by Blind1
Thanks Senix, that is where it's located. BTW - folks if you have to change a fuse in this box the part/object on top of the fuse box, is released via thumb screw, which either you to need to have small hands, or pliers. The clip of the fuse box is on front toward head light. Pull up and push it back.fficeffice" /><o></o
Old 10-02-2013, 12:53 PM
wp6529's Avatar
wp6529
wp6529 is offline
Ford refers to the fusebox under the hood as the "Battery Junction Box - BJB", and the fusebox in the cab as the "Smart Junction Box - SJB". The item mounted over the underhood BJB is the vaccum pump that supplies vaccum to actuate the 4x4 hub locks.
Michael53
2009 - 2014 F150
08-19-2018 03:30 PM
topdog49646
1997 - 2003 F150
09-06-2016 04:54 PM
bhobgood
17
01-20-2016 04:48 PM
luvemhot
04-19-2015 05:11 PM
Cannon51
02-28-2007 10:36 PM
Quick Reply: High Current Fuses Location on 09 F250 PSD 6.4
