6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Dented CAC
Old Oct 1, 2013 | 08:40 PM
aquaman's Avatar
aquaman
Dented CAC
I was driving down the road today until someone's ladder flew off his truck from the opposite direction and landed in the my lane. Fortunately, I avoided it but a bunch of dirt and rocks were kicked up and one piece appeared to
hit the bottom of my CAC putting a 2"x3" flat dent in 2 of the tubes. It looks like a rectangular imprint. The top and bottom of the dent looks a bit creased
How can I tell if it leaks? Can I simply put a dab of braze or solder on it to touch it up to prevent any leaks?
This sucks
Old Oct 1, 2013 | 08:52 PM
Tom's Avatar
Tom
The CAC is aluminum, and I wouldn't braze or solder it unless you really know what you're doing. I know there is a procedure to check for leaks but it doesn't look to be something that would be easy to do at home.
Old Oct 1, 2013 | 08:54 PM
bubbasz1's Avatar
bubbasz1
This sucks
Three way's I see to test for leaks, one pressurize and check for pressure loss, draw a vacuum down on it and check for loss of vacuum, or take it to a good radiator shop and have them check it for you.
Choice one or two will require a few tools and a little ingenuity, the third choice a few rubles.
And I know the feeling, had the same thing happen to me, only I was lucky enough not to sustain damage to my truck, good luck.
Old Oct 2, 2013 | 10:55 PM
aquaman's Avatar
aquaman
I guess I'll wait a few hundred miles and see if there's any soot/oil buildup near the dent.
I have a mess of oil/soot on the rubber boot on top of the CAC presumably from some minor leak somewhere where it is slipped on. The dealer said that was normal :-(
wycowboy
Jan 6, 2017 05:26 PM
entropyjones
25
Oct 10, 2015 11:18 AM
LSO1123
Mar 25, 2013 06:54 AM
p.j.
Dec 26, 2007 04:09 PM
dfawvor
Jul 2, 2003 07:59 AM
