High Current Fuses Location on 09 F250 PSD 6.4
Owner's manual says the high current fuses are located in the engine department. Well, if they are, they hide them prettied damn good. Apparently they are located under one of the batteries, but which one? Your help is surely appreciated. I need to replace a trailer marker fuse.
Thanks Senix, that is where it's located. BTW - folks if you have to change a fuse in this box the part/object on top of the fuse box, is released via thumb screw, which either you to need to have small hands, or pliers. The clip of the fuse box is on front toward head light. Pull up and push it back.fficeffice" /><O></O>
Thanks for this thread. I too had no brake lights or turn signals on my 2010 F-250. Checked the fuse box in passenger compartment. Didn't realize there was also one under the hood. Owners manual doesn't have that one documented. :-) The fuse for the trailer is a 25amp mini. Just FYI.
Here is a picture of the fuse box under the other thing with the thumb screw on it.
Thanks Senix, that is where it's located. BTW - folks if you have to change a fuse in this box the part/object on top of the fuse box, is released via thumb screw, which either you to need to have small hands, or pliers. The clip of the fuse box is on front toward head light. Pull up and push it back.fficeffice" /><o></o
topdog49646
1997 - 2003 F150
09-06-2016 04:54 PM
Cannon51
02-28-2007 10:36 PM
