Go Back   Ford Truck Enthusiasts Forums > General > Projects
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
  #1 (permalink)
Old 01-07-2011, 06:55 PM
nevrenufhp's Avatar
nevrenufhp nevrenufhp is offline
Garage is empty, add now
nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.
Lightbulb Gathering parts. Actual Ford diesel in 67 F100.
This will be the All Ford drive train Bumpside.
Still have a lot to get. I pick up the engine and Sterling rear in a couple weeks. For those that arent familiar with the Ford diesels, it's made by New Holland in Brazil. it's a 6.6 litre coming from a 92 F600. That gets mated to an Allison AT545(used in F600s, so I can claim it as Ford OEM), or possibly an AT1545(same trans, but has lockup converter). Then, the sterling rear for strength, and to match the F250 spindles I got from TigerDan a long while back. Front and rear sway bars, add hydrobooost, swap out the gas tank with a smog equipped one so I have a return line. Gotta box the frame all the way back to the leaf spring mounts. Chop out a new dog house & floorboard to set it back enuf to use a radiator, and maybe squeez in an intercooler/aftercooler. Not fully sure, but I may opt for airbags up front to maintain the weight of 1200 pounds of iron. Performance from this engine? for now, I'm going to see what all I can get out of it for cheap. Possibly around 300hp. I'll also have to re-gear to 3.08s to be able to run on the freeway with decent mpg. I'd rather keep the 300, if it meant putting a Cummins 5.9 in it. Nothing against em at all, there's just too many of em. Plus, the New Hollands have Ford script stamped in to the valve cover. Here's a representing photo of a 6.6:
Click the image to open in full size.
__________________
Dale.
turn up diesel fuel rate site of mine
67 F100, 300, 4spd, Offy 'C', Edelbrock 500, 274*/.518" cam, heddder.
82 Mercedes 300SD, mods to come.
  #2 (permalink)
Old 01-07-2011, 06:58 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Ford's name for the Allison is Transmatic.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 01-07-2011, 07:00 PM
nevrenufhp's Avatar
I was thinking of getting a 90s F250 aluminum rim set. The simple style with 10 holes. Traction will be a big challenge. May need wide meats.
__________________
Dale.
  #4 (permalink)
Old 01-07-2011, 07:02 PM
nevrenufhp's Avatar
Quote:
Ah, yes! Thanks, I'll have to use that name.
__________________
Dale.
  #5 (permalink)
Old 01-24-2011, 03:05 PM
nevrenufhp's Avatar
I picked up the engine last Thursday, and actually fired it up on Saturday. Sucker runs great, even though it's hard to tell in the video(in my sig). Bought it for $500, and just added oil and a gal of diesel. They even gave me the engine cradle. Far from being ready to put in, but at least it's mine.
__________________
Dale.
  #6 (permalink)
Old 01-24-2011, 07:22 PM
fordman75 fordman75 is offline
1996 Ford E250
My Garage
fordman75 has a good reputation on FTE.fordman75 has a good reputation on FTE.
Sounds like a cool project! I'm subscribing to this build! What made you decide on the 6.6L instead of like the 6.9/7.3L IDI? I think fitting the IDI would have been easier.
Do yo plan to narrow then Sterling rear so it fits your 67? Or are you going to run it full width?
And will just boxing the frame make it strong enough? That's alot of weight on the front!
__________________
Ted
1954 F100 4x4, 300, NP435/NP205
  #7 (permalink)
Old 01-24-2011, 11:00 PM
nevrenufhp's Avatar
I went with the 6.6 for a few reasons. #1, the 'Ford' oval on the valve cover and intake, for that extra touch of class in an old truck.
#2, the old hot rodder's motto of sticking a big engine in something it wasnt meant for.
#3, it has way more power potential than the IDI, and while I like the Cummins 6BT, there's just too many of em. I actually used to own a Dodge/Cummins, and this 6.6 sounds SOOO much better.
The downfall is the length, it's about the same as trying to put a DT466 in a Super Duty.
I'm going to run the Sterling as is, unless the width is really that bad.
Boxing the frame should be plenty for all I'm going to do with it. It's only about 100 pounds more than a 6BT.
__________________
Dale.
  #8 (permalink)
Old 02-21-2011, 08:14 PM
nevrenufhp's Avatar
I got it painted. Really changes the way people think of it, mainly the family. They still think it's ridiculously huge, but now the paint has them motivated too.
I'm sending out the intake and turbo compressor housing to get polished as a cheap advertising plug for a buddy's polishing biz. I'm trading a guy back East for a #3 bellhousing, so I can bolt the Allison to it. He wants my #2 for his MD truck. Here's what it looks like:
__________________
Dale.
  #9 (permalink)
Old 02-21-2011, 09:42 PM
1996 Ford E250
My Garage
Looks good!
__________________
Ted
Tags
66, 66l, 67, 67f100fordtruck, brazil, brazilian, diesel, east, f100, ford, grille, holland, litre, parts, size, tur
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
