2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Power Window Regulator
Old 01-02-2011, 01:13 PM
nelly0524's Avatar
nelly0524
nelly0524 is offline
This is my first post to this site... I have a 2008 Expedition King Ranch and just discovered that the cable to the window regulator busted... Don't know how. The cable is frayed at the bottom part of the regulator. (apologies if I'm not describing this correct) So I'm assuming the whole regulator needs to be replaced since the cable is busted, correct? Anyone have any idea what that would cost? I'm assuming the labor would cost the most, I found the part online for about $100... Any ideas or suggestions would be most appreciated! Thanks.
Old 01-03-2011, 03:50 PM
berry1234's Avatar
berry1234
berry1234 is offline
The labor is about one hour total. So whatever rate it's at $85/hr, etc.
Old 01-05-2011, 07:19 AM
Harley Guy's Avatar
Harley Guy
Harley Guy is offline
nelly0524 - just had mine replaced last week (driver's window) under my Ford ESP. Regulator was $98.49 and labor was $118.42 (1.4 hours). Regulator part number (Ford OEM) was 9L1Z7823201A. $0 deductable Found the part online for $74.00...
Last edited by Harley Guy; 01-05-2011 at 07:23 AM. Reason: part number was wrong in original reply
Old 01-14-2011, 10:03 PM
ZeroTucker's Avatar
ZeroTucker
ZeroTucker is offline
To avoid this cost: As soon as the window seems to be running slower than the others, pull the door panel off and spray some lubricant like WD-40 onto the cable while somebody runs the window up and down.
The cable hangs up inside the sleeve it runs through, overworks the motor and burns it up.
Old 01-18-2011, 11:57 AM
berry1234's Avatar
berry1234
I agree with Zero on all accounts except the wd-40. It's not a lubricant, it's a water displacer. Use a quality white silicone lubricant on the where the white plastic guides slide up and down the metal rails.
Old 01-18-2011, 03:42 PM
function12's Avatar
function12
function12 is offline
You can replace them yourself. The chilton manuals have a pretty good write up. Blue painters tape will hold the window up. Just use 5-6 pieces. I replaced several on my 2000 Dodge durango. Buy one with a lifetime warranty. I could get one replaced start to finish in just under an hour. Take lot of pics with a digital camera to help yourself out. Also, I would remove the old one and take with with you to the parts store. You need to make sure your get the correct side and correct door. They are usually not interchangeable.
You will be surprised how easy they really are.
Old 02-09-2011, 12:30 PM
cop on my back's Avatar
cop on my back
cop on my back is offline
I would like to know how the door panels come off. Don't get me wrong, I can do it, but it is always nice to know if there are any hidden clips or screws before you start.
This is going to be my next project on 3 of 4 windows!
Old 02-12-2011, 08:43 AM
gddyup's Avatar
gddyup
gddyup is offline
What I like to use in situations like this is liquid graphite instead of grease or something like wd-40. Like Berry mentioned, WD-40 is not really a lubricant per sae and the thing with grease is that it attracts dirt and can get gummy as it gets contaiminated. Liquid graphite is near perfect for something like this because the small graphite particles get inside the component in the liquid suspension and then when the liquid dries, it leaves just the dry graphite all over the place as a lubricant. It takes quite a bit longer to contaiminate since there's nothing really there for dirt to stick to.
Old 02-21-2011, 09:45 PM
cop on my back
Well, got all 4 windows done today and what a difference. No more squeeking and fast up and down. Just sprayed some good lubricant on the cables and grease on the tracks, voila!
Old 02-22-2011, 11:21 AM
berry1234's Avatar
berry1234
Good job. My passenger side had a horrible squeall when rolling up. Like rock on glass. Greased it up-both tracks-BOTH SIDES OF THE TRACK-cables, pulleys, pulley shafts, etc. Runs like butter.
Old 02-22-2011, 04:03 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
What did you guys use for lubricant? White silicone grease or liquid graphite or ........ ???
Plan on doing this soon.
Thanks,
Matt
Old 02-22-2011, 06:22 PM
cop on my back
For grease on the tracks, I used a marine grease (blue). For the cables, I used liquid wrench's lubricant.
Old 02-23-2011, 11:46 AM
berry1234's Avatar
berry1234
I used lithium grease for the tracks and a silicone type lubricant for the pulleys.
Cougstruck
03-29-2013 03:45 PM
Jay
06-08-2012 05:10 PM
Pilgrim
02-12-2012 03:33 PM
Quick Reply: Power Window Regulator
